H Herald Audiophyte Apr 23, 2018 2 0 1 43 Apr 23, 2018 #1 Dear All, I bought a Yamaha RX-V583 7.2 Channel AVR for my 11 x 16 feet room. Now, I want to get the best surround effect out of my RX-V583 7.2 Channel AVR having below mentioned specs --- 80 W per channel (6 ohms, 20 Hz-20 kHz, 0.09% THD, 2-ch driven) --- 115 W per channel (6 ohms, 1 kHz, 0.9% THD, 1-ch driven) --- 145 W per channel (6 ohms, 1 kHz, 10% THD, 1-ch driven) Rated Output Power (1kHz, 1ch driven): 115 W (6 ohms, 0.9% THD) Rated Output Power (20Hz-20kHz, 2ch driven): 80 W (6 ohms, 0.09% THD) Maximum Effective Output Power (1kHz, 1ch driven) (JEITA) : 145 W (6 ohms, 10% THD) Dynamic Power per Channel (8/6/4/2 ohms) : - / 140 / 170 / 190 W I already have a pair of JBL Control 1. Please suggest best center & surround speakers which would get along with my JBL Control 1. The last thing which I would prefer is let go my JBL Control 1. However, I am ready to compromise on my JBL Control 1 if there are no other options left. Reactions: andyblackcat
lovinthehd Audioholic Jedi Sep 11, 2012 44,861 0 113 Oakridge, OR Apr 23, 2018 #2 Best would be to have identical speakers all around. Get more JBL Control 1s if you like them so much? Reactions: andyblackcat
H Herald Audiophyte Apr 23, 2018 2 0 1 43 Apr 24, 2018 #3 lovinthehd said: Best would be to have identical speakers all around. Get more JBL Control 1s if you like them so much? Click to expand... I'm not sure if JBL Control 1 would work good as center speakers for the reproduction of the dialogues in movies
A andyblackcat Audioholic General Nov 10, 2014 1,138 0 83 Dec 19, 2018 #4 Herald said: I'm not sure if JBL Control 1 would work good as center speakers for the reproduction of the dialogues in movies Click to expand... I can say it will be okay and with all the same speaker and careful placement that will take some time using pink noise to check frequency/SPL levels and keeping the speakers at the same height elevation as well.
