Wall mounts, sub location, and center pulled forward.
psbfan9 Audioholic Samurai Apr 27, 2015 #41 Wall mounts, sub location, and center pulled forward. Attachments 046.JPG 35.4 KB Views: 755 049.JPG 35.7 KB Views: 721 051.JPG 33 KB Views: 752 053.JPG 24 KB Views: 752
fuzz092888 Audioholic Warlord Apr 27, 2015 #42 Looking good. Did you put anything between the clamp and the speaker?
psbfan9 Audioholic Samurai Apr 28, 2015 #43 fuzz092888 said: Looking good. Did you put anything between the clamp and the speaker? Click to expand... Thanks. The mounts came with a piece of sponge like fabric with tape on one side that goes on the clamps. That seemed thick enough, so I used it.
fuzz092888 Audioholic Warlord Apr 28, 2015 #44 psbfan9 said: Thanks. The mounts came with a piece of sponge like fabric with tape on one side that goes on the clamps. That seemed thick enough, so I used it. Click to expand... Nice, I don't think the one's I got came with anything. First time through I used blu-tac and right now there are felt pads with glue on one side stuck to everything. I considered using the screw holes, but didn't want to mess up the veneer.
afterlife2 Audioholic Warlord Apr 28, 2015 #45 I don't think you moved up the center speaker at all. Looking good. ENJOY.
psbfan9 Audioholic Samurai Apr 28, 2015 #46 afterlife2 said: I don't think you moved up the center speaker at all. Looking good. ENJOY. Click to expand... I swear I moved it! The picture is kind of deceptive because of the charcoal color of the mopad.
zieglj01 Audioholic Spartan Apr 28, 2015 #47 afterlife2 said: I don't think you moved up the center speaker at all. Click to expand... Put on your eye-glasses!
zieglj01 Audioholic Spartan Apr 28, 2015 #48 psbfan9 said: I swear I moved it! The picture is kind of deceptive because of the charcoal color of the mopad. Click to expand... So the hat hanging on the door - is that to control reflections?
