Can Anyone Help Me Track Down a Certain Vintage of Onkyo AVR?
Kaskade89052
Kaskade89052
The older generations of Onkyo AVRs have features I am very interested in (the "IntelliVolume" system, front panels that show the input name alongside the sound mode currently in use, aluminum faces, etc.) and after living with a Denon X2800 for a few years now that I picked up to replace an aging Onk 605, I'm convinced I don't care for the cheap build/knobs or sound of the Denon. As such, I'm back to looking for an Onkyo, but it can't be a new one because they're missing the aforementioned features (notably the front panels that don't allow for showing the sound mode in use in large lettering), and I really do not care for the aesthetics of the new ones coming next year (an important consideration for me).
I thought I had my search narrowed down to an RZ900, which shows the information on the front AND includes IntelliVolume, but the dimensions are just far too large for our entertainment center (in depth); someone is selling one for like 600 bucks on eBay, which seems to be a steal, but it just won't fit.
The RZ800, when I looked it up, is even bigger in the depth -- which is baffling -- so that won't work right now, either.
Does anyone know of any older RZ models (or well-made NR models) that offer a smaller footprint along with the features I'm looking for (the Onkyo IntelliVolume system and front panel like the 900 seen in the pic above)? I can't seem to hunt down exactly what I'm after, but I know I want an Onkyo and don't want the Denon anymore.
When did they begin building the AVRs without the input name and sound mode on two rows, as seen in the pic above? I'd want a model from just BEFORE that time period, even if it's a decently-built NR unit.
I of course realize I'd then have to hunt down one of these units in the wild, pre-owned.
If anyone could assist, it would be greatly appreciated.
Since Pre-owned is not out of the question, check there. They tend to have a good range of models to choose from with warranties and extended warranties. I didn't see exactly what you're looking for, but there's a good chance they have something like it.
Looks like not many Onkyos at the moment.
Kaskade89052
Kaskade89052
Thanks very much, J -- my apologies for not getting back to you sooner (I don't get replies anymore when I receive a response in a thread).
I appreciate you doing a bit of leg work for me on this -- I of course am aware of Accessories4less, so I'll look it over when I can.
The reason pre-owned isn't out of the question is because what I'm looking for is DEFINITELY not part of the brand's new lineup -- and, as I stated, I absolutely HATE the aesthetics of their new AVRs coming next year.
If you -- or anyone else -- has any insight with regard to what RZ or NR models I should be looking for with the features I want, I'd appreciate hearing it as I'm trying to figure out what vintage such a model would come from.
Thanks again.
carlosadar
When did they begin building the AVRs without the input name and sound mode on two rows, as seen in the pic above? Much like how 강남출장마사지 sets the gold standard for a premium and satisfying experience, finding the perfect AVR model from just before that transition guarantees you get the best display layout and build quality in a decently-built NR unit.
7-channel amplifier; 135 watts per channel with 2 channels driven hmm... not a very useful spec... so given they won't tell us the rating for 7 channels we have to assume it sucks bad. Surely at this point there must be some industry standard test driving 7 channels to allow for real world usage modeling/product comparisons?
Kaskade89052
Kaskade89052
What are you referring to -- the RZ900? Either way, multichannel AVRs are almost always rated with two channels driven (save for some esoteric types), and I just don't put much stock in these numbers because I've run systems with amps claiming to deliver "90WPC" or "95WPC" and they hit just fine.
You can work it out from the power consumption spec. Total power will be about 75% of the power draw at most, and then divide that by the number of channels. Actually the two channel rating is the max power and then you distribute that between 7 channels.
I suspect that if you actually tested most receivers to max power with all channels driven, most, if not all, would self destruct.
Mikado463
Mikado463
would Integra versions of that generation have the same ?
Kaskade89052
Kaskade89052
Yes, most likely -- but I don't care for the Integra design aesthetic.
Thank you for commenting; I don't see any messages any longer that there have been replies in threads I am part of, so my apologies for the delay in getting back to you.
