Think I should just leave them or try up front again n slide my couches back some
for me, it depends on where that puts you in relation to the surrounds. For some reason I think they might be wall mounted? Where are the couches now compared to where you started?
As much is like the look of them both up front, I believe in results, so I’d be inclined to keep them where they are.
Can’t remember the quote...lol
What’s funny too is when I had my pl200s hooked up I actually switched the phase on each of the rear ones and it did sound better. Idk why I wasn’t thinking that with these new ones. There’s still no comparison, the vtf3s are scary
I’ve always had to adjust the phase on at least one of my subs.One easy way is while in the LP, play the test tone in the avr, and have a lovely assistant adjust the phase on the rear one to whichever setting gives the most output on the spl meter.
One nice thing about the REW/minidsp(sick of hearing about that yet?lol) is you can adjust phase and gain right in the software. This makes it easier to make adjustments and measurements more quickly, and you can stay in your seat. There’s also a remote now which I believe let’s you switch through profiles in the minidsp so you don’t have to hook it up to the laptop every time you want to do something with it.
Edit: oh yeah, with those scary HSU’s it’s good to see you taking the effort to get it right. I think your getting pretty close to where you wanna be. Maybe not so much in looks, since the visual aspect isn’t probably what you wanted but even in a great looking room like that, I’d be more concerned with performance.
