2k Floorstanding Speaker Setup
Status
Not open for further replies.
N
Nuance AH
GUYs i think i found my sub!!! ITs a 1000 watt 15 inch at circuit city for $349.
Kicker VCVR152
Eeeeeeeeeeeeeerrrrrrrrrrrrrr (buzzer sound) - WRONG!
Like I said above, any of the cheaper subwoofers from the brands I mentioned will destroy anything from CC or BB. Check out Elemental Design's A2-300 or HSU's STF-2. Seriously, sloooooow down and read everyone's responses. Everyone has been very helpful, so check out what they have to say and look at their links.
Haoleb
Haoleb
Kicker VCVR152
Now your just pulling our chain arent you.
Size of the woofer and amplifier power have very little correlation to performance.
If all your concerned about is loudness, then maybe you should just go buy some big cerwin vega's and one of those afterburner subs.
mazersteven
mazersteven
You ask for recommendations. Then ask "what about these"? How about checking out and doing so research on what has been recommended.
That Kicker VCVR152 was NOT RECOMMENDED.
G
gus6464
There really should just be a sticky thread that just says the following:
"If you are looking for any speakers, no need to make a thread asking for suggestions. All you need to know is that ID speakers are the best."
Then just have a list of all the usual suspects and flavors of the month with an embedded script that's a dice so people can roll and pick one.
mazersteven
mazersteven
What are you recommending for $2000 with 4 floorstanding speaker from a big box store?
N
Nuance AH
No offense guys, cause I like you all, but this isn't helping the OP. Lets not get his thread closed, okay?
Again, no offense fellas. You're all very helpful, so let's stay the course.
G
gus6464
I understand. But what would be your choice for speakers.
For $2000 I would definitely move away from getting four towers and instead look into bookshelves.
Some combinations:
Paradigm Studio 20 fronts
CC-590 center
Paradigm Atoms for rears
SVS PB12-NSD
ERA D5 fronts
ERA LCR center
ERA D3/D4 rears
SVS PB12-NSD
Totem Dreamcatcher fronts and rears
Dreamcatcher center
SVS PB12-NSD
B&W 685 fronts
B&W HTM62
B&W 686 rears
SVS PB12-NSD
Out of all those I like the ERA and Paradigm combo best.
mazersteven
mazersteven
But the question was 4 towers for $2000. What 4 towers other then ID speakers would you recommend???
Paradigm Monitors?
Monitor Audio Bronze?
G
gus6464
Paradigm Monitors?
IMO the JBL L880 are better than Paradigm Monitor towers. Maybe PSB Image T45 towers if he can find a deal.
Status
