2k Floorstanding Speaker Setup
Status
Not open for further replies.
2
2005_gto
No THe JBL system is the one that im looking to buy.... Are you sure that boston will smoke the jbl??? WHATS THE BEST SYSTEM I CAN BUY FOR 2K WITH 4 FLOORSTANDING SPEAKERS?
Z
zumbo
We are aware of this issue, and are taking appropriate measures.
ABSOLUTLY POSITIVE! The JBL sub looks as though it may outperform the Boston for the price you listed, and can be used with the Boston system just fine. However, the price you listed for the JBL sub is extremely low. If it isn't coming from an authorized dealer, I wouldn't touch it.
mazersteven
mazersteven
Are you reading and clicking on the links that have been provided to you?
Post #17
Post #23
Post #25
G
gus6464
Have any of you actually heard the JBL Studio L series? I have heard both the Boston VR series and the Studio L series and there is absolutely no contest, the Studio L's are better speakers.
Audioholics reviewed the L880 towers, look it up OP.
2
2005_gto
But the JBLS have 2 6.5 inch woofers a 5/14 midrange 1 inch tweeter and a 3/4 inch tweeter.
2
2005_gto
The JBLS handle 400 watts the bostons only handle 250
G
gus6464
Can you listen to the JBL's? Don't just take anyone's word for it and listen to them first. Do you live near a Fry's by any chance?
G
gus6464
That means nothing.
Edit: Buy the 4 L880 towers and the LC2 center but for sub order an SVS PB12-NSD. You will be a bit over budget but the sub will be worth it.
Z
zumbo
I don't see the point of the above reply.
The Bostons have 2 7" mid-woofers
One 4.5" mid
And one 1" tweeter.
G
gus6464
$1362.28 for 4 shipped.
http://www.onecall.com/ProductDetails.aspx?id=20789
$358.97 shipped.
http://www.onecall.com/ProductDetails.aspx?id=88724
Member here has matching center for $350.00 shipped
http://forums.audioholics.com/forums/showthread.php?t=41144
$2071.25 This will smoke that JBL system.
May be used with the JBL sub if prefered.
Agreed this will SMOKE the JBL's......
Have either of you actually heard any speakers in the JBL Studio L line?
Z
zumbo
Dude, JBL can't touch Boston. If it were any other two speakers, I would chalk it up as preference. But here, your reply is absurd.
2
2005_gto
I plan on using the Onkyo TX-NR906 which is 145 watts RMS x7. And if i have to ill buy another amp. I live in oklahoma so i dont know if theres any places where i can actually listen to these
G
gus6464
LOL. My reply is absurd yet you have not actually heard both speakers. :rolleyes:
Z
zumbo
If your receiver claims 145 watts, then as long as the speakers you are looking at can handle close to that, then you are ok. There is no need for you to choose a speaker because it claims it will handle 400 watts.
Or, because it has two tweeters.:rolleyes:
Dealer locator:
http://www.bostonacoustics.com/DealerLocator.aspx
2005_gto
My receiver says its 145 RMS power per channel. THe JBL's say the handle 150 watts continous power
Z
zumbo
There is no need to get all caught-up in power specs. A speaker system that claims to handle 50 watts each will run off of that receiver. It's not that big of a deal. Seriously.
2
2005_gto
So then which receiver should i get?? Because one is $350 dollars the other is $2000
Status
