<font color='#000000'>SoftEng;
Thanks for the clarification on "Room Size". I will update my review accordingly. As for Master Volume Level max setting, it is independent of speakers. All I did was crank the volume all the way up with no source, certainly I wouldn't listen at that level!
Patrick;
To vary channel trims via EXT inputs, simply select "Ext Input" and adjust the levels there. These settings are independent of other modes of operation.
Dave;
Thanks for confirming "Presence" active preamp out to achieve 9.1 with external amp. That is excellent.
Ross;
<table border="0" align="center" width="95%" cellpadding="0" cellspacing="0"><tr><td>Quote </td></tr><tr><td id="QUOTE">Gene,
I know that the listed power consumption on the back of the unit says 500 watts. However, I believe that many other factors determine the actual output of the unit, and not just the listed power consumption. Are you saying that this is the only way you came up with the 80x5 wattage specs with the remaining 400 after the processors, etc. get their power? </td></tr></table>
The power consumption listed on the back of Yamaha receivers is not a max rating. Last time I spoke with them on this, they told me it was a typical power rating with all channels driven at certain %. I will ask them to comment in my addendum to the review.
Also,
I didn't quite follow what you were saying about the ultrasonic frequencies not showing up in the 10 band PEQ. When I've seen the EQ results from others on the web, I've seen boost or attenuation only at the frequencies that needed it. For instance, one speaker may have EQ adjustments at certain frequencies, but another my have almost completely diff. results. You can compare the front L and R channels in your review to see what I'm refering to. The second freq adjusted is 80 on L, and 160 on R. The third adjusted freq on L is 315 while it is 250 on R. I was just trying to figure out why yamaha was adjusting frequencies (ultrasonic) that I can't even hear anyways. </td></tr></table>
I originally thought the PEQ was only 7band based on the resultant read outs. Yamaha has informed me that 3 of the bands are not shown and operate beyond 20kHz. I am assuming this is for noise shaping, or sqaushing ultra sonic harmonics, but again I am guessing. This is yet another question I will pose to them.</font>
