Set your levels properly and don't drive the system too hard. That will generally prevent speaker damage. If you need the system to achieve life-like SPL or hit the same level as a commercial movie theater, you need to accept the fact that a consumer-grade system with a relatively low budget isn't gonna get you there.
Also, if you aren't aware, high SPL kills your hearing.
