That is my favorite site for calculators. I have yet to one single error in their posted formulae.
The problem is, though, that it's not.I would disagree slightly with hd, just slightly though. 2.83V/m is technically better/more electrically correct, but the W/m is better in one way. That is, if the manufacturer specified its speaker's sensitivity 88 dB/w/m, then you know it is 1W for 88 dB output at one meter regardless of the impedance.
When I mowed lawns for money I’d tell the ladies at the bar I was a land maintenance engineer. It broke the ice by making them laugh when they would ask what it meant.I'd put that in the same sense that the guy driving a bus is an engineer....
Did that sometimes lead to a pussy clipping?When I mowed lawns for money I’d tell the ladies at the bar I was a land maintenance engineer. It broke the ice by making them laugh when they would ask what it meant.♀
I understand your point, but most of what I read originally referred to 2.83V as the standard. It does cause some confusion as you mention if the speakers being compared are different impedaces. Then again sometimes sensitivity isn't in an anechoic space or measured over a wide enough range of frequencies. Would be nice for the industry to have a rock solid standard everyone stuck to.I would disagree slightly with hd, just slightly though. 2.83V/m is technically better/more electrically correct, but the W/m is better in one way. That is, if the manufacturer specified its speaker's sensitivity 88 dB/w/m, then you know it is 1W for 88 dB output at one meter regardless of the impedance.
That popular calculator we linked everyday twice on Sunday is based on W/m, so yes the user would have to make adjustments for speakers that have nominal impedance other than 8 ohms. I think I posted a conversion table recently for that purpose.
From what I've read the US is a bit unique in that....believe many countries have strict/proper definition of engineer.I don't know about the US, in Canada one can be sued for that if not actually a licensed engineer lol..
Dunno about the rest of the USA, but Texas indeed has strict definition of "engineer", and when that title can/can't be used.From what I've read the US is a bit unique in that....believe many countries have strict/proper definition of engineer.
My point has nothing to do with impedance curve or power output etc.. It was just about the use of the linked Homestead calculator.The problem is, though, that it's not.
Assuming that the measurement itself is accurate (88db @2.83v) then the actual wattage depends on frequency.
Let's assume that they measured 1w at nominal impedence of 8ohm on that speaker.
If at 12kHz it's 16ohm, then a sinewave at that frequency will only draw 0.5w to get 88db.
Conversely, if there's a 4ohm dip at 60Hz, that will pull 2w for 88db.
An ideal amp would scale the same way; so an amp wattage would be completely valid.
In the real world, few amps double power each time the resistance halves; though basically all increase somewhat.
There is no single w=spl relationship because no speaker has a flat impedance curve.
It was certainly the idea.Did that sometimes lead to a pussy clipping?![]()
Agreed, I actually developed my own calculator using Excel that allow inputs for sensitivity in dB/2.83 V/1M, or dB/1W/1M and for the dB/2.83V/1M format/standard, you can enter the specified "nominal" impedance of any value.I understand your point, but most of what I read originally referred to 2.83V as the standard. It does cause some confusion as you mention if the speakers being compared are different impedaces. Then again sometimes sensitivity isn't in an anechoic space or measured over a wide enough range of frequencies. Would be nice for the industry to have a rock solid standard everyone stuck to.
That's what I've been saying..! Hahahow skewed are the sensitivity ratings from the companies in home audio?
I know in the car audio industry they just throw the numbers around and when you calculate it a woofer boasting a 91db rating realistically have 87db. obviously these numbers mean pretty much nothing to us as we tend to over power our woofers with 1.5-3x the rated power to combat impedance rise but were just trying to get loud lol.
IIRC many don't measure sensitivity below 400hz, so not much use for the woofers generally....tho you probably won't see a sensitivity spec for the majority of active subs for home audio either, usually that's more a diy thing.That's what I've been saying..! Haha
That is why the calculator will always be an approximation of need and cannot be an accurate measure of need... sensitivity cannot be measured (accurately) in watts... at least not without factoring in ohms.My point has nothing to do with impedance curve or power output etc.. It was just about the use of the linked Homestead calculator.
That calculator requires the following inputs:
- Speaker Sensitivity in dB/1W/1M (M is meter)
- Amplifier Power in Watts
- Distance in feet
- No. of speakers
- Speaker Placement (relative to walls or corner)
So when the user enters the input "Speaker Sensitivity", he/she has to be careful because if the speaker's specified sensitivity is in dB/W/M, then there is no need to be concerned about the "nominal impedance" of the speaker. If the specified sensitivity is in dB/2.83V/M, then the user has to know the "nominal impedance" of the speaker in order to do the necessary adjustment, simply because that calculator expects the sensitivity to be in dB/1W/1M.
As @Beave mentioned before: "Amps are designed to be constant voltage sources, not constant power sources." So like @lovinthehd , I also prefer sensitivity to be specified in the dB/2.83V/1M standard, but reality is that many manufacturers are still using the alternate dB/1W/1M standard. My additional point to HD's is simply that in a very narrow sense, dB/1W/1M is better if the regularly linked Homestead calculator is used, because then the user would not have to make any adjustment to the calculated result, or in entering the input field "Speaker Sensitivity. That's all..
Keep in mind when a speaker manufacturer claims 90 dB/W, they likely did measure the spl output and the applied voltage, not watt, then they would calculate/convert whatever dB at 2.83V to 90 dB/W as though the speaker was an 8 ohm resistive load but that it actually wasn't. That is, sort of creating a mathematical equivalent only. As you alluded to, you really can't measure spl per watt unless the load is a resister, but a resister won't produce much spl just by buzzing..That is why the calculator will always be an approximation of need and cannot be an accurate measure of need... sensitivity cannot be measured (accurately) in watts... at least not without factoring in ohms.
