DIY is also a good path with learning to maintain, upgrade, or even repair your factory equipment as well.
I'd much rather DIY than always compromise with budget/factory considerations, even if I had to leave them without finish.
I've just built a set of mains, and a sub, and now I'm already looking at building a pair of these and a sub for my shop and I am not even completely finished with the current sub build. The inukes are portable. I could easily take the one amp to other room since it only weighs around 8lbs.
http://www.diysoundgroup.com/waveguide-speaker-kits/fusion-4.html
Oh yeah. DIY 'is' addicting. One sign that it's leaning towards obsession is you will start doing things like keeping a tape measure at your computer for scale.
I have the inuke 3000dsp powering the ultimax 12" and this thing is badass. The inuke has a usb patch so that you can tune the entire op from your pc, which is where I play my music from anyway. It is a beautiful thing. Yes, there is fan noise, but I usually have a fan going in here all the time anyway.
