a/v moron said:
It FREAKIN WORKS..... woooo-hoooo
Excellent.
Ok then, a couple of points to note:
1. Referring to page 45 (point 3) of your receiver's manual, you should be able to see what signal is 'incoming' to the receiver and what is 'outgoing' from it (by changing the upscaling value from page 88 'HDMI upconversion'). Note that when playing DVD's, you should find that you
won't be able to upconvert, even if you have told the receiver to do so, because DVD's are copy-protected (if you try using an old VHS player if you have one you should find that you can upconvert to anything though just to prove to yourself everything works as normal).
2. Assuming your picture isn't fuzzy with DVD's, it sounds like something might be up with your cable box or the signal you receive. However, if you never used to have this problem with your picture (if DVD's aren't fuzzy, it'll prove that the connection from receiver to t.v. is ok), then it still sounds like a setting somewhere might need to be fixed. Let us know and I'm sure we'll all try to help.
3. In the event that you don't already know, the best analogue cable to use for video (from worst to best) is composite, then s-video, then component. You previously asked if there was a loss of picture quality between HDMI and component cables. The answer is that it depends. Some folk say that HDMI gives a superior picture. Others say they can't tell the difference. Some even prefer component to HDMI. I think it may depend upon the particular pieces being connected. Only you can decide, though to make a valid judgement, you should calibrate your t.v. input to each first.
4. In terms of audio, it's generally preferable to use either a digital coaxial or digital optical cable. Both will give
identical quality of sound, though most people prefer to use a coaxial cable as it tends to be a more robust connection.
a/v moron said:
The picture still sucks. I think it is my actual cable feed coming into the house though. Someone told me about a cable "booster" that is available. Do you think that this would clean up the image on the tv? I thought my old TV was just a piece of crap, but now I am thinking that it was alright just has a bad feed to it. Any thoughts?
Refer to point 2 above. If your t.v. picture sucked before, then perhaps it is the cable signal thats not very good after all. As for boosters, I can't help I'm afraid. I've no experiance with them. Sorry.
I'm really happy you seem to have got things going. If you've any other questions, just fire away. We're all here to help.
EDIT: I've thought about what I wrote regarding not being able to upconvert DVD's and think I might be mistaken.
I cannot with my receiver, but then, my receiver doesn't have HDMI jacks. Since HDMI sends an encrypted signal and cannot be 'hacked' as you know due to the HDCP 'handshake', it may well be that
you can upconvert DVD's. The easiest way to find out is simply to try and take a look at the Audio/Video Information screen to see what is 'incoming' and 'outgoing'.
One last point; If when watching DVD's you notice the picture isn't quite right (maybe the top few lines of the picture are a bit skewed for example), try turning off the Video Processing of your receiver (page 88 of the manual). In some cases this can interfere with a signal (this is why THX recommends that it isn't used for DVD's).
Enjoy.
