SVS SB-3000 vs PB2000 pro
  • Thread starter Thread starter ssv1899
ssv1899
6
0
1
22
Confused on which subwoofer I should get as there many mixed opinions on ported vs sealed for a home theatre.
My room size : 18x14x9 (2300 cu.ft approx)
As of now I can only get one subwoofer, the pb2000 pro and sb3000 are about the same price here in India, looking for advice.
Edit: also considering the pc2000 pro as it would be a smaller footprint.
If size isnt an issue, get the PB-2000 Pro or PC-2000 Pro.
I am also considering a Tonewinner D4000, but haven't seen many reviews of them. They are also in the same price range as the svs subs, so wanted to know how they would compare.
You will likely not find any reviews with CEA 2010 ground measurements.
They are a rather new brand compared to SVS. SVS has always been well regarded and well reviewed with excellent customer service.
The only argument you will read about SVS is they are more expensive than internet direct companies. But for the additional expense you get well reviewed and trusted Subs with world class customer service. And most importantly, peace of mind
Thanks for sharing, I'll definitely think about it.
