wilkenboy said:
Man, thats is a LOT of stuff all hooked together. I'd love to see your wiring diagram. The place where you buy your interconnects must be on a first name basis with you...
~Josh
wilkenboy
Well join me on MSN messenger chat and I’ll explain the wiring diagram it was kinder easy to figure out.
The connections like RCA phone leads are as affordable as you can get and still I’m amazed with the detail in the sound.
Fronts will let’s put it this way. I can send the monaural centre phantom that exists between and on the left and right fronts to the centre channel while in Dolby Digital 5.1 mode or 4.1 makes no difference, try doing that on your AVR or AVP and the solution to this is very easy as well.
It’s a Matrix affair. While some dislike the use of it, and while I can give greater spread of the sound over the three-screen with constant activeness if I was in the mood, its simple press of the button.
MACCA350
As for April I was doing this since summertime 2006 and it’s still not complete as of yet, thou I have been thinking x32
JBL Control 1 for the surround array is kinder pushing it, may x22, anyway I’ll play I by ear for now. It sure sounds (((surrounds))) great.
