Wow, full Class A huh? It should save money in the winter on your heating bill!
Seriously tho, if you're paying for an electrician, I would still have them run a couple 15 amp lines simultaneously for everything else now and in the future, especially since you're not going to want to have anything else plugged in to the 20 amp circuit. And it looks like you have quite a bit in your family room system - assuming that's where this is going.
Not sure if you're using any power protection, but I have been using APC H15's
https://www.amazon.com/APC-H15BLK-12-Outlet-Rack-Mountable-Conditioner/dp/B000FBF08Q for my two 15 amp circuits as insurance against the fairly regular fluctuations I have in my area. There is an active relay that balances over/under current which is the wearable component and fails in 7-10 years according to APC (just lost my first H15 after 8 years, but all my amps work fine 8+ hours a day, so I find value in that peace of mind).
I thought APC made an H20 but I am sure you can find a similar product for the amp. Good luck!
