Power quality for speakers
no. 5
no. 5
Thanks for the links mtrycrafts. :)
Looks like goooood reading. :cool:
So i have experenced there is a difference matching your speakers to a Amp/Preamp .
As I said, I do agree with matching difficult to drive speakers with robust amps that can deliver high current on demand in order to obtain optimum performance. Beyond that I don't buy.
Joe Schmoe
I agree. I think that power (including current, headroom, etc.) is the only difference between amps. I don't think that an amp has a "characteristic" sound otherwise (nor that it should.)
no. 5
no. 5
respectfully, I disagree with some of that statement, an amplifier shouldn’t have a "characteristic" sound (that is, if you are going for absolute fidelity, if you’re going for just something that "sounds good" well.... ;) ), and as it has been pointed out many times before, they often don't.
However, as an example, in my post number 37, I referred to the specs of a few amplifiers to the effect that (within a bandwidth of 10Hz or 20Hz to 20kHz) the frequency response can deviate up to 3dB above and below a flat response, so that would mean that two frequencies that are the same level on a recording could have up to 6dB deference in volume when played back, perhaps a somewhat extreme example, but still possible.
Personally, I feel that two amplifiers can sound deferent, there is no way the deference could be "night and day". :)
(hope I did'nt start a flame war :eek: )
