Hi all,
I've been following the thread for a while now and decided last week to get my Z7. Picked it up on Saturday and spent the evening setting it up and testing a few things which all seemed fine.
Then this morning I decided to try out the decoding on the amp from my Toshiba HD-XE1 and so enabled the Direct Digital Audio Mode option. Tried out Transformers for about 30 mins and all seemed well, then moved onto the Pianist to test DTS-HD MA and within the first few minutes I started to see vertical blue speckled lines in some particularily dark areas. Switched inputs around and this stopped it for a while but it started again shortly afterward
. I had tried a number of HD-DVDs on Saturday evening, although not in anger, and I'd been conciously looking out for this issue but saw nothing; then watched Cloverfield SD DVD and that was fine.
My receiver sits ontop of a media unit in open air, so there should be absolutely no chance of an overheating or airflow problem.
Also, I noticed a bit of a delay on the audio layer; took about 5> seconds for the sound to start on the Cloverfield menus, but once it was synced and there it was fine. Think I've also seen/heard this on HD-DVDs today, but certainly not to the same extent; gut feeling is that it's the XE1 causing that, but it's no big thing really.
I did email Yamaha UK last week to ask about Gene's findings in this thread, but they haven't got back to me yet so I'll take it up again with them tomorrow. I'm really hoping they can come up with an answer soon; I so don't want to take this beauty back because it's a significant upgrade for me (from a Denon 2805) and the sound is immense.
I've not had an enormous amount of time to play around with it so some things are probably not configured correctly, but I'm a bit alarmed that I've hit this particular problem, and soon after setting it up.
Guess it's also worth mentioning that this is (as far as I know) a UK DSP-Z7.
Cheers
