Hi Folks!
I'm new to this forum and new to the RX Z7 (just got it two weeks ago). I'm been lurking here for some time now and finally decided to post. Generally, I'm very pleased the unit, but ufortunately, I too have the blue-vertical lines and occasional sparkles when running HDMI-HDMI with processsing turned on. I've updated to the 1.05 firmware, but that didn't make any difference.
Some partial good news tonight.
Yamaha sent me some beta firmware (ver 1.05). Some preliminary tests I ran tonight indicate I no longer get the blue lines but do get occasional blue sparkles with HDMI to HDMI processing engaged. I will be doing more extensive testing tomorrow and a followup addendum in my review onces it posts this coming Monday. Maybe Ver 1.06 will put this issue to bed???
Gene, your post references a beta firmware version 1.05 ... and then later references 1.06. Whereas 1.05 is already out, can I assume you meant 1.06 or am I misundersanding your post?
While I'm at, there are three other minor "annoyances", one of which may not be the fault of the Z7, although I'm not certain.
First, as has been reported by many 3900 owners, I have the problem in which my Motorola (cable) STB is reset from 1080i back to 480i (not even 480p) when I turn on the receiver. Ultimately, I'm not certain whether this is a problem with the Z7, the STB or perhaps even the TV itself ... or a combination of all of the above.
Second, I don't like the switched outlet being tied to the main power switch as opposed to having it tied to the unit going in and out of standby. If you want to keep the amp in stand-by mode (for the purpose of remote control via network) then the switched outlet remains powered all of the time.
Finally, I seem to be having a problem with the Receiver Manager software. Although I can consitently access the Z7 using the web interface without any problems, the RM software works only intermittently. Most of the time, it can't see the Z7 on the network. I'll try reload (and refreshing) numerous times but the Z7 will never show up. Then, every once in awhile, perhaps after a dozen or more attempts, I'll launch the RM software and the Z7 will be miraculously listed ... in which case I can use the RM perfectly. I posted this problem on another board, but never got any response.
Still, these are all minor issues and they're not stopping me from enjoying the unit.
