Newbie needs help with a Pioneer VSX53 and subwoofer issue.
  • Thread starter Thread starter DaveStre
DaveStre
13
0
1
49
Hi folks, hope all are well and thanks for taking the time to read this thread.
I am having an issue getting output to my powered subwoofer. I can hook up the RCA to a regular channel output and get output, but the subwoofer channel is dead.
I have done so far:
Multiple system resets
Tried setting speakers to small, then large with either the sub set to "ON" or "Plus"
I have tried a different subwoofer.
None of which helped. I have tried all the different sound and movie modes to make sure LFE was being sent to the sub (in theory).
I love this receiver, it powers my KL777x's very well, and I hope to keep using it...if I can get this sub channel active.
Any and all help is greatly appreciated!
I have done so far:
I note that receiver is a very low priced receiver and known for a lot of trouble. I note Amazon have it in clearance at a very low price now. I just don't see how something as complex as a receiver could be built with any degree of quality for the price offered.
If you have subwoofer set to yes, , crossover set to 80 Hz speakers set to small and activate the test tones to the sub, then you should hear it. If you can drive the sub from an alternate source, and you know you cable is good, and you don't get sound from the sub, then the receiver is defective. Just one other thing make sure you set the crossover on the sub to the highest frequency and turn the sub gain all the way up.
If you get no sound under those conditions then there is nothing you can do except go receiver shopping.
  • Agree
  • Like
Reactions: DaveStre and Trell
I have a feeling the crossover setting is the missing piece, but I cannot seem to access it's frequency settings. I will review the manual again for that. Thanks for the help so far!
Doubt this guy is in the market for that!
I am not sure what separates are, but I am already shopping for an amplifier now versus older style receivers. I am just looking to play my records, no need for most of the other features as I already have an EQ in the circuit between the turntable and receiver.
Look on page 71 and 72 of your manual. You can set the crossover frequency from 50 to 200 Hz. You must set the output level. I note the sub output setting is zero db. So you will get no sound until you set the sub level above zero db. I bet that is your issue.
So when I go into the x-over settings the first option is set to 50 Hz, so I bump that to 80. As for the next options, should I set them to next highest value, or try to set everything to 80 Hz? It seems the system is looking to move all settings up a notch.
You also have to advance the sub volume as the default setting is 0db, and you will get no sound. Advance it to + 12 db. at least.
  • Like
Reactions: DaveStre
So when doing the sound test, I cranked up the sub level, which makes it thump, but, it also pulses the left channel speaker and goes back to no output. Nice thing I found is, I was able to make my 2 main channels sound better than ever with some tweaks. I might just give up on the sub at this point :)
In that case you have it set to large and LFE + main. You need to set your speakers to small in the menu.
  • Like
Reactions: DaveStre
I did that, still nothing. But, I have adjusted the finer things in the channels, crossover, etc and my vintage speakers sound like I remembered them back in the late 70's. Before, they were very shallow and weak. Now, the woofers pump hard and the highs and mids are far crisper. I always kinda wanted to remove the sub from the system, seems like that day has come. Since the sub and everything worked prior to a recent move, I can only assume some sort of damage occured during the move.
I sincerely appreciate all the help to this point!
Have you looked at "channel levels" in your setup menu or ran Auto setup ?
You don't have to have a surround system to do this.
Highly unlikely that only your sub output is bad and the other ones work.
  • Like
Reactions: DaveStre
Yes, I have turned the sub levels to the max (+12) with no change
The range of the sub level is -10 to 10 per the manual; zero is merely the midpoint.
Yeah, I don't know where I got +12, but yes 0.0 to 10. When I crank that up, the sub thumps on the test, but does nothing after test is done and setup exited.
It should also go to -10. Is this per page 41? 0 is just a default setting and generally you will have sufficient output especially if gain on your sub is maxed out. What sound mode are you playing back in?
I use the various music modes/presets typically since I have an EQ in line from the turntable to the receiver.
Earlier you said LFE, which is different from redirected bass. LFE would only have content with the right source that includes the LFE (.1) channel. Just checking to make sure the modes you're using permit use of sub with 2.0 sources....you may have all this down, just checking to make sure we're on the same page. All I can figure if you are getting some sound out of sub....
