Yes I mean bookshelves on stands. Since I have the sub it no longer makes sense to get towers, correct? Since we were talking about towers before, any recommendations on bookshelves?
Sent from my iPhone using Tapatalk Pro
All speakers in an HT setup will benefit from a subwoofer. Including big 3-way towers. And now that you did that, plan on buying a second next black friday! Always match your subs up in a dual sub system. There are ways around it, but it takes a lot more experience than I have to solve those issues. Alas, I digress.
My previous advice stands. Listen before you jump.
Your value of buying small now against perhaps being in a larger space in another year can still work. Buy Standmounts and Center now, use your cubes as surrounds. Buy matching towers after you move. Or buy towers and matching center now, use your cubes and expand later.
Use magnolia to go hear stuff. Find other local audio stores if that is an option. Look at Crutchfield, they can be a great source, with a much larger selection than BB/Magnolia. If you are remotely interested in the ID companies, call and talk to them. Look at reviews online where you can, but remember, those are all subjective, but maybe can help you find the direction you want.
