I know, and have read the linked article more than once. I actually meant for example you didn't always measure IMD, and I found the SNR section could be made a little clearer, so people (like me
) don't have to assume things.
Example:
So it seems you measured the RR2150 at the power amp output and the Denons at the pre-outs? If so, then I have the following questions:
I usually measure preouts of AV receivers to make sure they are clean and able to drive at least 2Vrms to best mate with externala amplification. In the case of the RR2150, nobody would be using that as a preamp only so I likely reasoned to just measure from input to speaker output.
- For AVRs, did you always measure in Direct mode at the minimum, and with DSP only in some cases?
Yes usually direct mode and then with DSP engaged to measure bass management circuits.
- Did you always use 100 mV in, or whatever it needs to obtain 1 Vrms at the pre-out?
Typically yes unless otherwise noted.
- In addition to measuring SN or the prepro section, why wouldn't you measure the overall SNR of AVRs from input to speaker output as well, so we can compare SNRs of AVRs (when used as prepro only) to prepros, and also AVR to prepro/power amp combos.
I do. When you see my 1watt SNR measurement that goes from preamp (100mV) to speaker output (8 ohms, 2.83V).
It will be great if, for AVR, receivers and integrated amps, we can see the SNR values for:
- Preamp input to preamp output (e.g. 100 mV in, 1 Vrms out).
- Preamp input to speaker output (e.g. 10mVin, 1 W out, 100mVin, 100 W, or rated output)
I usually do exactly what you're saying unless I'm using an HDMI input which I will set either to -10dBFs or 0dBFS depending if I'm testing bass management. My test conditions should be noted in most cases however if I differ.
Sorry about asking so many questions, I do appreciate the fact that the AH test lab has already gone way over and above anyone else in the business, in providing so much valuable information and making it publicly available, for free. Thanks again for the great work!
