H Hetfield Audioholic Samurai Nov 23, 2016 2,781 0 63 50 Oct 3, 2021 #21 Any suggestions for a short stand for the 570s to raise then up 10-12 inches? I haven't found anything reasonable, any suggestions? I think they are just a tad short and raising them up a bit is needed. Sent from my Pixel 4 XL using Tapatalk
lovinthehd Audioholic Jedi Sep 11, 2012 44,878 0 113 Oakridge, OR Oct 3, 2021 #22 How far off from ear height are the tweeters as is?
Eppie Audioholic Ninja Jan 22, 2021 4,082 0 36 The Great White North Oct 5, 2021 #23 Hetfield said: Any suggestions for a short stand for the 570s to raise then up 10-12 inches? I haven't found anything reasonable, any suggestions? I think they are just a tad short and raising them up a bit is needed. Sent from my Pixel 4 XL using Tapatalk Click to expand... That's about the height of a small subwoofer. Haven't been able to find anything under 15". May have to DIY something. Reactions: Hetfield
H Hetfield Audioholic Samurai Nov 23, 2016 2,781 0 63 50 Oct 5, 2021 #24 Eppie said: That's about the height of a small subwoofer. Haven't been able to find anything under 15". May have to DIY something. Click to expand... I've found a solution, non HT solution. Wood stepping stool with rubber on the bottom to keep it steady. Sent from my Pixel 4 XL using Tapatalk Reactions: Eppie
