Paul McNeil
Thanks, 'Isolar', I think my point is a good one: why invest in the gear if the data falls short. Is there some other way I can put this question more directly?
Trell
Trell
I see your point...
I get a good laugh over on AVS when users sweat bullets over buying a television with the best possible specs, only to watch nothing but garbage quality streaming on it.
Makes zero sense to me.
So no, there is no point. (in that case at least)
Heh, while I mostly watch streaming content I like the wide viewing angle of my LG OLED. That was a major reason as to why I held on to my old plasma for so long and not buying LCD.
isolar8001
isolar8001
You don't have to steam...I don't, and never will.
I knew even back in the 70's that no system was any better than its source material.
If you can afford the gear, you usually can afford the better sources.
Trell
Trell
The gear is not an investment but consumption.
Paul McNeil
We're all equal.
Paul McNeil
Haha, yeah (see my gear), if I watch only BluRay discs. But's that not what you or I do, I'm guessing. Be honest!
Paul McNeil
May I say, that, in my opinion, this forum is totally worthless. But that is not surprising, so are most of these. Goodbye all.
You really came on here and acted like a prize "twot". Your first post was incomprehensible and looked as if it came from a bot. We have had some bots lately.
We certainly don't tolerate fools gladly here, and I certainly don't. You have put yourself well into that category in the space of an afternoon or less, and rated high up that category to boot.
I really don't think you could contribute anything useful to these forums, so your early exit relieves us from wasting time with you.
NINaudio
NINaudio
It might have helped if you could actually formulate a coherent question. It took quite a while and some teeth pulling for people to even get you to tell us the gist of what you were trying to ask. But that didn't really happen until page 2:
But the answer is no, you don't need the highest end equipment to get the most from streaming sources. They are by nature compressed streams and you will lose something over watching on a disc.
For movies/shows where picture and/or audio quality are important to me, I will always opt for physical media over streaming if available. I invested in the gear I did for when the source doesn't fall short, not for the lowest common denominator (compressed streams).
Paul McNeil
Just bullshit, and enjoy. My question was clear, from the beginning. Does data incoming limit quality out, from a high resolution system? And data incoming is less than optimal, no? When have you spent too much based on the incoming data? Why are you guys so aggressive? Why?
Paul McNeil
By the way, you are not scary, with the tattoos!
William Lemmerhirt
William Lemmerhirt
My thoughts exactly. ATV4k has been very good for me, but when it really matters, I buy the BD.
William Lemmerhirt
William Lemmerhirt
Clear? It’s not even English. Or maybe you’re in kindergarten learning sentence structure. Or drunk!
Or insert the word “is” between when, and all. Then it would make sense. Try proofreading.
