{sarcasm on} Well, if all amps sound the same then I guess it's a no-brainer for line stages. I mean seriously, they don't even have to amplify - just switch... And since wire is wire and most switches are just flat chunks of wire, then they can't be any different. Right? And seriously, CD players just read 1 and 0 and pass it out to an external D/A converter - how can they sound any different? {/sarcasm off}
While amps may sound almost identical in small comparisons and with speakers that are relatively easy to drive, there are situations where they are very different.
Teke for instance a pair of Apogee Duettas and a pair of B&W's. The B&W's are relatviely benign and something like a Proceed AMP2 and a Classe whatever (level matched identically) will sound very similar (though differences are there) on the B&W's.
Switch to the Duettas. The Proceed will fall apart - no bottom end, no dynamics, very flat sounding. The Classe will drive them just fine - bass is there, they still image, they still have some snap, etc.
Why? Power supply, output impedance, dynamic headroom, etc. When not needed on a relatively benign load, the differences are not as apparent. When the going gets tough, it shows. Most amps won't even WORK with the Duettas (< 2 ohm load in places). That's a HUGE difference in sound (nothing because it physically goes into protection mode vs. music playing
I guess my point is that just becasue 1 comparison over a relatively short time doesn't show something statistically significant, that doesn't mean that it might not in another, in another system, etc.
Just my 2 cents.
