helppp!! not new to car audio but stuck on this...
annunaki
annunaki
Moderator
Understood here, but everything is in check. 25 hz is not too low on this woofer by any means. I would personally have gone lower but space constraints don't allow it.
K
killakilck123
This is true, but tuning too low also runs the same risk at certain frequencies above Fb.
I didn't do any modeling so I don't know if you tuned too low or anything, btw. Just saying that you don't want to tune too high OR too low.
how do i tune it? i dont know anything about tuning it. but we will start building tomorrow
Alex2507
Alex2507
how do i tune it?
That term refers to the combination of the volume of the box, area of the port and length of the port to produce a desirable frequency response curve (graph showing the output).
Annunaki has everybody's highest confidence.
Put your faith in him but send your money to me. :)
Z
zumbo
Annunaki has everybody's highest confidence.:)
I had to fix this.
Put your faith in him, but send your money to me.:D
K
killakilck123
okkkk
so im starting the build today folowing annunakis steps. ill take a few different pics. ill post either tonight or tomorrow morning
Thanks
L
K
killakilck123
ahh
i started the box already but my dad was confused on the demensions of the vent.. he doesnt understand the demensions you gave so can you simplify those for me? just on the vent... we made most of the cuts but i want to make sure he puts the right spacing in between the walls. so can you maybe draw a sketch on paint and write in the space between the walls if you know what i mean. i need to know by tomorrow or the next day bcuz we wanna finish. so please let me know asap guys thanks
L
K
killakilck123
ah wtf
ok zumba the post yu sent me for those jbls already expired can you find another one for me that i can trust? im trying to buy them not so please let me know asap
thanks
L
Alex2507
Alex2507
From post 83:
The vent dimensions in each half of the enclosure will be:
Height: 18.5"
Width inside of vent: 1.625"
Depth: 39"
If you think of it as two boxes sharing a common wall each vent needs those dimensions. Is it the decimal system that you're not getting? If it is the height is 18-1/2" and the width is 1-5/8" ... I hope that helps but I'm not sure where the confusion is.
K
killakilck123
ok i gotchu now. can you do me a favor and check out that link that zumba posted for the JBL gtos and find me a deal on those. i just want to make sure they are the right ones for the dementions annunaki just gave me since the box is mostly built alredy.. so please let me know asap
thanks
K
killakilck123
yeah so far i have it all built i just have to cut slots for the vents. and im waiting for subs to arrive. monday or tuesday they should be here
Z
zumbo
Did you make pics during the build?:confused:
That would be great for the thread!:D
K
killakilck123
IS IT RIGHT SO FAR GUYS? I WASNT SURE HOW LONG TO MAKE THAT SHORT PIECE ON THE VENT.. I HAVE EXTRA WOOD SO PLEASE LET ME KNOW ANYTHING THAT LOOKS WRONG AND I WILL FIX IT ACCORDINGLY
PLEASE LET ME KNOW ASAP BCUZ AS SOON AS THE SUBS COME IN MONDAY IM GOIN TO FINISH SO IF THERES ANYTHING WRONG I WANNA FIX IT TODAY. ALSO WHERE SHOULD I PUT THERE BLACK N RED SPEAKER TERMINALS? I BOUGHT A FEW OF THEM.. I WAS THINKING ON TOP OR BOTTOM SO IT DOESNT INTERFERE WITH THE VENT? LET ME KNO GUYSS
THANKS L
Z
zumbo
I sent annunaki a PM stating you had posted pics. His answer will be the best, since it is his design.
Pretty impressive, I must say.;)
Z
zumbo
If I have read correctly, the total length of each vent should be 39". The sum of all three pieces in each J.
Wait for annunaki before you take my word for it.
K
killakilck123
ok i just did measurements and the length of the J is 41in so yeah i will have to take a few inches off then.
but let me know anything else..
Z
zumbo
Wait though. I have a feeling the middle piece needs to be shorter. Not the end piece.
,_|
