jamie2112
I would keep the Behringer as well, its got tons of power for later uses as wellpersonally, i'd keep the Behringer EP2500 ... it's still THE bang for the buck amp for ANY subwoofer or any speaker you desire.
Not that I need the extra power, even though I have had the clip lights come on a time or two. But I like the extra headroom. Im getting two of these amps and the zpre and some other speaker thing for $400 locally, So I can sell my amp, and the zpre and come out with money left over or at least come out even. But instead of having one amp and one power supply and 700 watts or so Now its like im running monoblocks with 1400 watts per sub.Why sell the EP2500 and get two RMX1450s? Just get a 2nd EP2500 and that substantially exceed two RMX1450s.
And in practical terms; you already get approx. 125dB at 20-30hz with one EP2500 on those subwoofers. Why do you need 1 more watt of additional power, even?
-Chris
I just think the EP2500 would probably be a better amp. That's all.The EP definetly wont be taking the place of my mono's it may have more power, but just... no.![]()
The Ep2500 has all high quality components internally; certainly at least as good as my McIntosh MC754 amps used, and in many cases, better(the Ep2500 is chock full of 1 percent tolerance metal film resistors, boat loads of Toshiba output transistors, massive power supply system and it uses a mil-spec redundant layered circuit board). And the EP2500 is built superior, physically, from what I can tell.I dont know what their SNR but I find it hard that the EP2500 could be better sound quality wise. Just plain component quality wise it isint. Looks wise it most definetly isint.
Sure I could take a few hours and do some listening tests but lets be frank. Everyone would just tell me its the placebo if i heard a difference anyway. Be it my Odyssey monoblocks that sound better or the behringer.![]()
Do you have ear plugs?So, when you are going to tell us what SPL you achieve with 1400 x 2? Do YOU have the balls(to risk frying your subs)?
-Chris
What do you live in a barn????So, when you are going to tell us what SPL you achieve with 1400 x 2? Do YOU have the balls(to risk frying your subs)?
-Chris
-Chris
