Looking to run a true 5HZ signal to my Sub woofers but think my anthem receiver will Bottle neck this.
Allen Vos
Actually, I did not pull it out of thin air, I used the info I had, but I accept your info is likely correct, but it has made no significant difference except to minimally reduce the power handling with the lower number. This xmax is not worth arguing over, as it has no practical significance. If you don't high pass the driver as it reaches its excursion limit, then you stand a very good chance of ruining the driver. Look it up, sealed designs need low and high passing and all commercial sealed designs have that, and plate amps for sealed designs also have that ability. This is part of speaker design 101.
PLEASE STOP TALKING
Allen Vos
This positioning doesn't often align with where one's spouse says the subs work best though. Haha
For sure man...... Im just going to stop speculating and focus on learning how to setup the subs via REW software and the mini dsp. Its the only way Im going to sort out bass nulls and frequency cancelation. This seems liike the best option righ now
Allen Vos
You are determined to find out the hard way!
Alert the media, everyone! The Resident Audio Ancient has spoken! I'm sure I'm about to suffer a catastrophic subwoofer failure any second now. Just like all the other users currently enjoying single-digit frequencies with zero issues. Clearly, your vast knowledge of 1950s gramophones makes you an expert on modern subwoofers. It must be exhausting being so confidently wrong, especially when the manufacturer literally states these play down to 0Hz. No one wants your "help." Please go back to yelling at the neighborhood kids to get off your lawn.
Yup, that sums this bloke up Verdinut. Just have to add, as a rock!
AWE, is someone butthurt they got called out on their lies? LMFAO
Obviously you think Thiel and Small were also liars, and that their work was of no consequence. I told you nothing that was at variance with their work. You can't begin to design a speaker, without understanding their work and its consequences.
Allen Vos
Oh, look at you go, Grandpa! Back at it again with the creative writing, putting words in my mouth like you're some kind of culinary artist.
How many times do I need to repeat this before it finally pierces that absolute fortress of a skull? You got caught red-handed cooking the books. Your little fairy tale completely fell apart, meaning your credibility is officially sitting at absolute zero.
I am just dying to hear more of your incoherent, babbling nonsense—oh wait, no, I actually kindly asked you to shut it. On top of that, you love sharing your completely unasked-for opinions while dodging direct questions like an Olympic athlete.
I do not want your help. Which specific syllable of that incredibly complex concept is failing to register in your brain?
Allen Vos
To anyone still following this thread, going back to the original question, that everyone should have been focused on, lol, I setup REW on my laptop and connected to my Anthem MRX1140 via HDMI and ran some test tones.
With Arc correction on, I was succesufully able to play test tones right down to 2 hz and watch the movment of the existing paradigm subs.
This only confirms my original question, that the Anthem will in fact pass all frequencies through it with or without the ARC correction on.
I can not confirm any kind of output though as I dont have my UMIK-1 mic
A big thank you to those who put genuine effort into trying to help me with this.
I feel it might be time to just lock this thread as to turn commenting off
m. zillch
m. zillch
You could also buy a complete stereo for as little as a few hundred dollars to watch your subwoofer cone(s) move but the pertinent questions are:
- is it doing it at anywhere close to the correct level at the listening chair?
- is it doing it cleanly without distortion?
- is it detectable to a human being by ear or tactile sensation alone (so no eyes looking at cone motion nor analyzer display panels allowed)?
The answer to all three is: "No".
m. zillch
m. zillch
This one often fools hobbyists. They play, for example, a 10Hz tone, but their overall reproduction chain has trouble doing it cleanly, so it spits out a signal with harmonic distortion which is the original sound mixed with spurious, undesirable, new "distortion products" at multiples of that tone— so 20Hz, 30Hz, etc.—and those they do detect (because they are in the audible frequency range, not infrasonic) and are hence fooled into thinking: "Both my system can produce, and I can hear, 10Hz because I just tested it for myself and I heard it!"
Here for example is a graphic showing the expected harmonic distortion generated by a 100Hz tone:
People with small systems that can't faithfully play 100Hz would report that they can "hear the bass" but they are simply hearing the higher distortion frequencies of 200Hz, etc., and are being tricked by that distortion.
As they upgrade their system so it truly can properly produce the lowest frequencies (and at adequate clean levels) their next limitation is when the frequencies become so low they are infrasonic hence undetectable. . . . unless they are elephants.
You are absolutely correct. When you attempt what the OP wants to do, you generate harmonics of the fundamental like crazy, including even and odd harmonics. That will be inevitable with the OP's plan. It is the audio equivalent of the alchemists' "Fools Gold." With a big paper cone like that, it will really break up and generate harmonics.
By the way, that slight discrepancy in xmax was irrelevant. I did remodel it, and it very slightly but insignificantly reduced output below F3, so it went in the opposite direction from the slightly higher F3. The alteration in performance was totally insignificant and did not alter the model in any significant way. So the performance was very slightly degraded using the lower xmax figure, which is exactly what you would expect. Less cone movement, less output and that is obvious.
Allen Vos
To clarify, the goal of this discussion was simply to confirm whether the Anthem unit could pass a 5 Hz signal. Now that this has been successfully confirmed, the purpose of this thread has been fully resolved. Thank you all for the input.
Allen Vos
Oh, wow, look at you go, you absolute titan of intellect!
What specific syllable in "facts vs. opinion" is currently giving your fading brain cells such a massive workout? It is truly inspiring how you keep drooling all over this thread with your uninvited, deeply pathetic needling—even after being explicitly told that your "help" is about as useful as a screen door on a submarine.
But no, 2,000 polite hints later, and you are still stumbling around here. You have proven yourself to be a flawless monument of negativity and sheer incompetence. Honestly, you should probably take notes from that other user who perfectly branded people exactly like you as the Audioholics Hyenas. Yes, genius, that glorious title was custom-tailored specifically for you. But hey, I guess being completely, mind-numbingly stubborn is your only real personality trait. Truly hilarious!
