Enough for REQ, just for now
. Now some objective stuff:
The physical differences between the two are as expected, significant:
- People who like the gold/copper color and dislike the port hole, will prefer the Denon's front view.
- approx a lb lighter than the AV8801, 30.8 lbs vs 31.6 lbs (on my best bathroom scale, not by the specs on paper.
- The X4400H is about 1/4 inch less in height, that allows me to put one of my Infinity fan (@ADTG would know those things are relatively tall/or thick?) on top and still have a 0.5" gap (from the upper shelf) for it to breath.
- no more gold plated connectors, rca and all, Denon website says yes, they should fix that to avoid being accused of false advertisement. The gold plated ones were found on the AV8801 and my old AVR-4308CI.
- The display's color is blue, more like my old Sony ES, don't like it now but may get use to it.
- The display's resolution is poor/cheap looking, but so it the $3000 Marantz, iirc, the X4500H will have a higher resolution one, finally, or hopefully?
- Two attachable antenna for wifi, that is supposed to help, but I haven't tried it yet as I always hard wire it.
- Features I don't use are absent, i.e. Ethernet hub, balanced inputs, 7 ch analog in, remote control out, etc.....
- The X4400H has a much better vented top, so two small Infinity fans should solve all potentially heat related issues, including longevity.
- Less crowded internal, the AV8801 is jammed packed inside.
If one can forgive the plastic front of the Marantz, there is no way this cheap Denon can produce sound quality comparable to that of the Marantz, based on the physical differences/build quality.
I suppose if you magnify the above by a factor of 2-2.5, it should be how @ADTG must have felt about his first AVR-X3312/or 3311? looking at it side by side with his $7,500 AVP (that lasted only 8 years though).
On the electrical/audio side:
- AV8801 has the TI DAC, 1795, that is basically a modernized 1796 found in the Denon AVP and their second from top universal players, and top BR players.
- X4400H has the AK4458VN. On paper it has lower THD and higher DYN than the Yamaha X-A2070's ES9006A. I am happy to know it is the same one used in the Marantz flagship SR8012. The AV8801's TI1795 is only better in DYN/SN.
- The EI core transformer looks well shielded vs the AV8801's apparently oversized toroidal transformer.
- The power supply caps look small, my guess is that they are no more than 12,000 uf X2. Edit: Actually 15,000 uf X 2.
- X4400H has the latest surround formats, but also lost a couple of old ones.
- Has better 4K upscaling, can do 60 Hz, the AV8801 just 30 Hz.
- Audyssey calibrations is quicker in calculating at the end, this thing must have more powerful DSP than the much older AV8801.
- It seems to run slightly warmer than the Marantz, understandable because of the addition bias current of the power amp section, though should be more efficient as it is a newer design, and I turned the ECO feature off.
To state the obvious, I consider this an upgrade for what I need in terms of functionality and features, but a clear down grade in terms of build quality and electronic/electrical componentry in general.
For a subjective review on music and movie performance, I am going to need probably another week, after I have enough time to re-watch movies and music files, discs that I am very familiar with.
