3805: Bi-Amping compromises and CRT interference
Purchased a shiny silver Denon AVR-3805 based on your initial impressions and acolades given to all things Denon (in every publication you care to mention).
(1) Bi-Amping:
EAGERLY read the review, especially the bi-amping section as I'm running 5.1 with no zone 2.
EAGERLY bi-amped my mains according to your exact instructions, which worked and had the exact unity gain of +2 db with my SPL at 75 db.
EAGERLY listened as my Paradigm Monitor 7v.3's pumped out 240 watts of....what?!...background noise???
As it turns out, Gere was correct in his review of the 5803, there's a reason Denon "...did not provision preamp couplers for this task (bi-amping)...they did this for a very good reason, eliminate a path for noise. Ordinarily I would have questioned that, but the very fact that year after year, Denon products, namely their receivers and DVD players always measure some of the lowest noise floors in the industry as illustrated by their exceptional Signal to Noise (SNR) measurements in all modes of operation conducted by various audio publications."
Well, I'm not questioning Denon's logic as bi-amping raised the noise floor enough to hear it from the listening position, and I'm not talking quiet passages from a poorly recorded CD with the volume set at reference level. I'm talking no signal, with the volume raised just above off (-80 db). Sob
Quite a contrast to the ABSOLUTE SILENCE I originally experienced (and Denon is famous for) connecting one set of speaker wires with jumpers in place. A glaring ommission in as detailed a review as one is likely to find. The culprit is high Zone 2 volume levels necessary for unity gain with the "front" amplifier channels. This noise, although significanly softer, is envoked with a single speaker cable connection by raising the Zone 2 volume level to +2 db, bi-amping...well...amplifies it. Turn your main volume level with no signal to +2 db and you'll see what I mean.
2) CRT Interference
Since introducing the 3805 to my system I've noticed green discolourations on the corner and outer edges of my Sony KV34HS510 HDTV. It occurs regardless of running the video direct to the TV or through the 3805. My mains and centre are magnetically sheilded, several feet from the TV and I've purchased good double sheilded video cable with source ground.
Since removing the Monster HTS 1000 MKII it has diminished significantly, but is still ever so slightly visible (hey, I'm a perfectionist, that's why I buy this stuff). I feel it's the AC, in particular, the 3805 sharing a power line with the Sony. Anyone ever come across this? I've been battling it for a month and I'm at the point of tweaking pleasure crossing over into stressful vexation!
