Contest for Rives Audio CD...
Hi,
This is my first post as a new Audioholic member...
1. What percentage of importance does the room make in the overall sound quality? (i.e. Amp is 15%, Speakers are 30%, etc.)
The room is the first thing we start out with and the last thing most of us think about... Sometimes, you don't really know what you're missing until you have the right equipment to hear it, and then you really can see how the room setup, speaker placement and even furniture have a significant influence on the sound. Since equipment has such low noise and distortion, as well as relatively equal frequency response throught the analog range, the room acoustics might affect certain frequencies in either boosting or attenuating by significant amounts... This is what I've found to be true in my system... So, in my long-winded answer, I believe the room has a significant (ie.... greater than 50% influence on the over all sound of your system) if such a percentage really exists. Actually, the percentage is not really the issue... Treating the room as a component of your syetem is what needs to be done ! And... can be the difference between poor and great sonics !
2. In terms of money spent on your system, what percentage was spent on the room including design consult and treatments.
In my case, as I would guess in most others, little was spent on the room versus the equipment... I have actually spent about $200.00 or less than 0.5% on the room versus my equipment. However, as I have my new house built, I plan on taking the room in to consideration first in terms of dimensions and in isolation as well as balancing it after I get the equipment set up, and use an SPL meter to determine the frequency signature of the room...
Stay well...John
My System :
BAT VK-31SE Tube preamp
2 - BAT VK-55 Mono tube amps
BAT VK-D5SE Tube Red Book CD Player
BAT VK-P5 Tube Phono Preamp
VPI HW19 Turntable Audio Quest PT5 arm and Ortofon MC50 cartridge
Sonus Faber Cremona Speakers
Analysis Plus Solo Crystal Oval Interconnects and Oval 9 Speaker Cable
Adona Corp. Isolation Equipment Rack and Mono Amp Stands
4- Sonex Wall foam acoustic squares
