Awesome! I have just the place for these Intimus Outdoor speakers...
In-Wall: If I were shopping for a projection solution instead of a flat-panel, I would be strongly inclined to buy an in-wall solution because at that point, I would be working on a dedicated theater. I would certainly want a center channel that was identical to the left and right channels.
Front-Tower/Bookshelf: If I were buying my first flat-panel, I would shop for a 5.1 front-tower setup (and definitely not a 7.1 setup because I don't believe there is enough truly 7.1 content to warrant it or that the added channels provide significant improvement over 5.1). Because most of my experience has been with direct radiating surrounds, I would go with di- or bi-pole surrounds this time. In fact, I would definitely spend that extra money on a second sub for a 5.2 setup.
Surround Bar: A surround bar option would only make sense for me if I were putting a flat-panel up in the office (we avoid electronics in the bedroom to minimize distraction
Smallest On-Wall: I would avoid the smallest possible on-wall system because the acoustical comprises would not make sense for me; I use my system almost exclusively for movies and require a large and deep soundstage. Additionally, when I begin to acoustically treat my room, I would not be able to put early-reflection absorbers behind the on-wall speakers.
Wireless: Wireless is a great idea, but I haven't yet seen a dependable solution that makes enough sense for me yet; one still needs to route power to the speakers with wire. Perhaps the closest thing I would consider at this point are solutions that route the audio signal through existing in-wall power lines.
Outdoor: We host get-togethers fairly often, so if I were putting a flat-panel up on the balcony, outdoor speakers would be essential because TV speakers are simply inadequate in an outdoor, unsealed environment. I probably would not opt for a subwoofer in this scenario.
Thanks, Aperion; love your stuff, and your business model.
