Midwesthonky
Contest Questions:
1) What are your home theater system components, including manufacturers and finishes / colors?
2) What would you change in your home theater system?
I would like to add rears for a 5.1 or 7.1 setup, possibly upgrade the sub. Eventually upgrade the receiver.
3) What would you upgrade 1st in your home theater system?
Add rears for better home theater. Music is run as 2-channel (shuts center off)
4) When you chose your speaker system, how important was it that the subwoofer finish color matched the rest of your system? Scale: 1–10 (1= Didn’t matter at all, 10 = Had to match finish color). Please explain.
1 - the subwoofer only needs to work with the room, not the rest of the system as far as color/look is concerned. My existing sub is a plant stand. Shakes them up some during movies, but is generally not even noticed in the room.
- Amp/Receiver
- Yamaha Rx657 receiver - Speakers
Front L/R = Axiom M60v2
Center = Axiom VP150v2 - Sub(s)
old Pioneer SW-105 - Sources
CD/DVD = Oppo BDP-83 blue ray player
TV signal = Time Warner Cable, may go back to DirecTV
Sometimes run mp3 player into receiver via 3.5mm to analog L/R cable
Nintendo Wii
- AV furniture
standard leather couches & chair w/ottoman - Other
