Dual Opposed Mach 5 Audio FTW Build
  • Thread starter Thread starter fuzz092888
Coming along I see. For keeping enclosures square the corner clamps are a must for me. It takes 8 of them, but they are worth every penny
Must be nice to have rich man clamps. I'm a poor man getting by with pipe and corner clamps. Seriously this is almost finished. I hope he has a good lawyer on speed dial for handling noise complaints.
I have some corner clamps, but they haven't really worked out. I should probably look into different one's some day.
The Bessey's have been awesome. No regrets there.
You're short a few clamps. Before your addiction is done, you'll be making and installing your own cabinets , building furniture, and changing the oil in your vehicles. Old Alex seems like the right mentor..
Good job sir! It should be smooth sailing from here. I'm always nervous on glue up. I've had a couple times when a foot was 10 inches on a cut.
Thanks, lots more to do, but it should be 100 times easier once I get the wheels on. I'm thinking I'll probably glue or epoxy the wheels on and then bolt them instead of using screws. Hopefully that should keep them pretty secure when trying to wheel this thing around.
Well, a couple moves and job changes later and I'm circling back to this build. I stored the cab I built for this, but at some point there was a leak, the bottom got wet and now it is basically just mold. So I guess I'll be rebuilding. I'll probably be around the same dimensions, although I think I'll be doing plywood this time instead of MDF. Should be a good time.
Since Photobucket sh!t the bed I'll upload some new pics.
That sucks about the mold. I now have scavenged a couple of pallets and, at a minimum, put anything important that I store in my basement on two by fours.
My current basement stays dry (many haven't in the past), but there is always the risk of a hot water heater leak or the condensate pump from the AC unit failing, etc!
  • Like
Reactions: fuzz092888
I hear you. This was actually at my Dads business. We put it in a place where it never leaked before, but as luck would have it there's always a first time for everything :rolleyes:
The thread is only two years old. This is hardly a revival. More like being nudged awake in church before the sin of snoring.
You're actually ahead of schedule.
I actually found the zebrawood baffles for the NaO Note II RS yesterday too. So as soon as my local supplier gets more plywood in I'm going to swing back and grab some. The only parts I'm missing are the tweeters............
  • Like
Reactions: Alex2507
