Thanks for the reply Peng... I guess I should have said I didn't see any instructions with adjusting the curves or rather what the curves do. I guess the App is more geared to those that understand setting the frequencies, etc.
I understand setting crossovers but anything much more I'm lost. So any suggested starting points that I don't need a Degree to understand to get a better handle with frequencies. Thanks again...
You can use you finger to alter the shape of the target curve. It is a very clumsy way obviously, but it is definitely better than no way. Keep in mind, just because you shape the target curve, it does not mean the actual result will follow exactly but it will try, and can be quite effective to correct the bumps. For dips, it will be hit and miss because there is a limit for how much you can boost, and in many applying boost would just be a waste of amp power to a large extent depending on those "room modes".
In my experience, XT32 typically would result in a flattened response from 15-200 Hz, say within +/- 3.5 dB, using the Editor App would allow me to get it within +/- 2.5 to 2.75 dB and then by manually fine tuning the phase and the subwoofers build in PEQ, +/- 1.75 to 2 dB is possible, based on 1/12th smoothing, or +/-2 to 3 dB with no smoothing applied. All my measurements are done using REW and Umik-1 mic.
