I know it's a 3930 thread but in many repects 3930 and 3910 are similar, so maybe I'll find some advice here
Upgraded recently to my Denon 4306/3910 combo and my TV monitor is PIONEER plasma 1080i. The setup is simple: 2 HDMI cables between player->receiver->TV, 1 DL3 cable for audio. Another HDMI cable connects STB SA 8300HD and 4306 which finally works fine (thanks to the recent COX firmware upload).
I am very satisfied with the audio
, now is the time to tweak some video signals (which I don't know much about). So, here come my questions to the more experienced users:
1) Since the max signal accepted by plasma is 1080i should I choose INTERLACED vs. PROGRESSIVE in my 3910 video output format (thus avoiding de-interlacing)?
Does it make difference at all (I could not notice) ?
2) Assuming I choose 1080i as the resolution output from 3910, it should not make difference if I choose 1080i or THROUGH as the "HDMI video out" in my 4306, right? I think -in either case plasma should get the 1080i signal.
3)When I choose 1080i as the HDMI out, no matter what comes as the source , should come out as the 1080i signal, right ? So the TV should not do any more processing/deinterlacing/scaling, correct ?
This is how I think it should work, BUT...
4) When use I the SA8300HD/4306/PIO connection, the signal should be upconverted in my 4306, right ? (I choose "AUTO- HDMI/DVI" in the STB's output). But when I hit the Display button on my TV's remote, it shows me the native reoslutions (480i, 720p, 1080i) depending on the station's signal.
I though they ALL should have been upgraded tp 1080i.
So, what's going on here, is my 4306's upconverter not working or am I missing something ?
5) Also, can the RIVA calibration disc, which is on its way to me, really help me with the issues above ?
6) Lastly, there'e a lot controversies (this Forum included) regarding issue of "scaling" done by 4306. I could not find a word in the manual, the product sheets advertise it, but the Denon rep I talked to says that the only Denon receiver which does that is 4806CI. Any comments ?
Sorry for the long post
- I am putting copy of it also in the 4306 thread ...
