Yet you seem to believe other things that are not necessarily more important than copper shielding.
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Copper shielding is in theory a good idea and it actually can help dissipating heat if used properly. I understand you have bad experience with the 8801/trigger but many are happy user. I have learnt from you experience and installed two fans but have forgotten to turn them on a few time and found the temperature to be only in the high 40s even though I have only 2 inches of clearance on the sides and top to ventilate. Just about every brand and model, if you Google hard enough you bound to find reports of failures. I bet that will be the case with the 8802 but only time will tell for sure.
