Axiom Audio EP500 VS SVS PB12-Plus/2
  • Thread starter jc1carter829@ho
  • Start date
Sheep
Sheep
I can't believe this is how people react when being called a liar. There are many worse things to be called in the English language.
Call me crazy, but when someone calls me a liar, I flip them the burn and continue on my marry way. Besides, I didn't lie, so I have nothing to hide. I always thought if you have nothing to hide, why make a big fuss?
SheepStar
craigsub
SheepStar
Some day, when you are ALL growed up, you will learn that a man's word is the ultimate measure of his worth. Until then, you might talk less, and listen more. ;)
I
Ilkka
craigsub said:
Ilkka, Until you actually make blind testing a part of your subwoofer tests, you are running half a test.
This is going way OT, but I'll answer to these questions.
Yes, I agree that blind listening (or even open listening) would add more info to my measurements, but unfortunately it's just not possible. You can not compare my "shootouts" to for example Ed Mullen's subwoofers reviews. They are totally different. Yes, we take almost exactly same measurements, but Ed does it only for a single subwoofer at a time, I prefer to measure as many subwoofers as possible. First time I measured eight different subs/different tunings, all in around 5-6 hours. I have lined up around 12 subs for my next session and I'm planning to measure them in less than 6 hours. It is just impossible that I could listen to all of those subs in my own room. Or even outside like Yates did, I just don't have enough time for that. I have already tested my own subs, so all the upcoming subs will belong to my friends or forum members, who will be driving them to my measurement session. I can't just take their subs and keep them in my room (also space is one issue) for several weeks, which proper listening would require. I don't also get paid for doing this (for example like Ed or Yates), so I'm not willing to do that amount of free work, which proper listening would require. At least here in Finland most of the forums members where I have posted the results, have been very surprised how I even do this amount of free work. They understand that listening them is just literally impossible. But don't get me wrong, if someone wants to give me the subs and pay a reasonable amount of money, I will gladly do a similar test like Yates did, it would be very fun and instructive.
Same thing with AV Talk. They just CAN'T add any listening tests, since most of the subs belong to the fellow forum members.
You also set abritrary test parameters which favor SVS. For example, you decided to use this "10 % THD + N" for your max output charts ..
Yet, in comression tests, the EP-600 delivered 99 dB @ 20 Hz ... Someone looking at this chart would think the EP-600 to be a poor performer. You KNEW this when you posted that chart.
I originally choose the <10% THD+N test because both Tom Noussaine and Ed Mullen are using it. I didn't know if it would favour SVS or any other brand. It was also chosen because I (or anyone else using TrueRTA) didn't know how to take THD sweeps. I completely agree that <10% THD+N tests doesn't tell the whole truth about subwoofer's performance and that's why I also used the other kind of test to measured THD levels, especially at lower levels, because we don't always listen to your subs at max or near 10% THD level. But the program I used for these "poor man sweep tests" turned out to deliver skewed results, if one would adjust the output level from the wrong place. This happened with Axiom (I take the full responsibility of this error, but it was VERY cold out there and I hurried..and made an error). I also made the error that I posted that graph (which I later deleted), which I shouldn't have done. I didn't look at it so carefully when posting it, but when you pointed out the errors, I knew it couldn't represent its true performance.
You should also know that I won't be using the <10% THD test anymore in my future measurements. We have developed a new test and it will show subwoofer's THD level at all measured levels and frequencies, from bottom to top. Just wait for the new shootout results, I think you will like them very much. And since EP-600's "THD sweeps" results were skewed, I will be measuring it again using these new tests we have developed. Also there will be much more subs to be tested at the same time than SVS PB10.
I, along with several dozen other people (including Bossobass, who knows a few things about subwoofers) in our home, AND every other reviewer who has experienced the EP-600 has raved about its performance. At NO time is distortion audible with the EP-600.
I don't believe EP-600's distortion can be heard when using program material. I have only measured the numbers using sine waves, but never claimed it would have audible THD when using program material. I have claimed that one can separate a 10% THD at 20 Hz from 1% THD and I stand behind that statement.
And yet, Ilkka, I have seen several e-mails in which you told people about it having "cone cry, farting ... etc ..."
That is impossible with the EP-600. The DSP will not allow that to happen.
Maybe you don't remember this, but I explained this to you over at AVS in a PM discussion we had around a month ago. When I got the EP-600, I had some difficulties in achieving a flat in-room FR. I tried the same place where for example Ultra produces a quite flat response, but still I couldn't get a good response. Then I thought it must be related to EP-600's front firing configuration and therefore I placed some books under its each end and used it as a downfiring sub. Surprisingly FR was better, but the performance was lacking badly. Of course I couldn't tell this by then. I ran many tests between it and the Ultra, using the same TrueRTA "peak hold" method as you use, and of course was listening at the same time. During those tests I heard cone cry, farting and the performance was clearly lacking. There was a good 2-3" distance between the driver/port and floor, but apparently this wasn't enough or maybe the DSP didn't like the downfiring configuration. After those tests I wrote that ONE e-mail to Jakeman, who was at the time still my friend, where I wrongly blaimed it for bad performance, when it actually was caused by me. After those tests I found out a really good spot for it (corner) and was surprised of its enhanced performance. I also wrote a correction mail to John, but you probably never saw that one. I haven't heard any additional noises from it since.
The EP-600 will deliver, @ 20 Hz, a 99 dB signal @ 2 meters ground plane with no audible distortion. The 86 db you list in the chart is totally mis-leading.
I can not change the "rules" for every sub I test. I chose the 10% THD test and of course every sub was measured using same criteria. But as I said, there will be new tests and you won't see those 10% numbers any more in the future. It is okay for us to develop and make our tests and measurements better?
The comparison tables using the data from 10% THD tests were made for you all. They were made to help comparing the clean output of tested subwoofers, but as I said, 10% THD doesn't necessarily represent the "clean" output limit especially at lower frequencies.
You also still have this diatribe in your review ...
You cannot do a listening evaluation with the EP-600 ?
I have tried to replicate the problem you had with the Avia disc, TrueRTA, Emotiva Test Tones ... etc ... it is no harder to calibrate than any other subwoofer.
It's not hard to calibrate it, if the output level is high enough. It's the gain which doesn't stay linear. Like I said in my review, subwoofer's output jumps suddenly ~10 dB at a certain output level, which is around 80 dB in my room. And it doesn't depend on subwoofer's gain setting or receiver's sub output level. Ian Colquhoun explained to me that EP-600 has this kind of function, with it tries to bring the noise level lower. Unfortunately it also affects on test signals and music signals too, at least with my EP-600. If you have a larger room, meaning you will have to calibrate it to a higher level (above this jump level), one could easily miss this behaviour.
Finally ... you promised, in writing, to send the subwoofer back to Axiom. That promise is still in your review.
Yes I did. I said it because I suspected that there might be something wrong in my unit. But since then I have heard at least two other units having this same odd behaviour, so I'm thinking it is perfectly normal. I don't see why I would need to send a working sub back? It just doesn't work well in my small room and with strong room gain it has. I am going to sell this unit soon, so maybe the next owner has a better luck with it. If not, he can probably contact to Axiom and see if they can think a fix. I have been humiliated and accused of having bias and God knows what else by Axiom, so I don't want to have any kind of businesses with them anymore.
craigsub
Ilkka .. When you said this :
You said a mouthful. It is impossible for you to retain objectivity when this is what you think.
I
Ilkka
RMK! said:
Ilkka,
Why don't you start your own thread(s)? There, you and like minded individuals can post your graphs and enjoy the visual side of Audio to the fullest. You won't get the exposure you would by posting in more popular threads but at least it will be peaceful and you will no longer have to worry about being unjustly persecuted. Just trying to help:)
I will must definitely start a thread of my own when I need to, but since there are some questions asked from me in these threads, it's okay for me to answer to them here? It would be silly to start a new thread for my answers. But generally I see your point and agree with it. :)
I
Ilkka
It is possible that the treatment Axiom has given me, would affect on my subjective opinion on their subs. That is one reason more why I don't want to post my listening opinions for it. It's only fair to both subs and their companies.
But it WON'T affect on the measurements I take. TrueRTA or Spectra doesn't care how Axiom has treated me. Numbers don't lie, I believe you have that kind of saying over there.
jakeman
The saying is "Numbers don't lie, people do".
craigsub
Ilkka, Axiom treated you very well. You really need to get past this, if you plan on furthering your "reviewing" career.
Look at it from their point of view. You put the word "wimpy" into a review of their product. You had a chart of their product showing it delivered 40% THD at 85 dB @ 20 Hz. You said it was a poor performer while you were using it as a down firing subwoofer, and decided to tell people later about the down firing part... You are the ONE person who has had this "negative" experience with the EP-600. If 8 other reviewers had posted what you did, then there would be some merit in regards to what you said. Heck, if ONE reviewer had made declarations which were even CLOSE to what you said, there would be some merit.
As a reviewer, you are supposed to be independent. You are supposed to ignore all the rhetoric going on around you. Your job is to make sure you get EVERY possible aspect of performance from the product. Until you are honestly doing that with every product you test, your reviews will be tainted.
For my end, I will look at your new review methodology, and will respond according to what is in the content. Nothing more, and Nothing less.
By the way ... In regards to the whole IMD vs. THD debate: I said months ago that this IMD issue would be no more important than the THD issue. And it isn't.
Sheep
Sheep
I love how SVS can have out-of-control fanboys, but Axiom can't. :rolleyes:
SheepStar
craigsub
SheepStar
You really are getting to be an obtuse young man. Who said Axiom cannot have their own fanboys ?
In an earlier post, this is what I said ...
This is the perfect definition of a fanboy. Every company has theirs.
If you need assistance in translating that, just ask.
I
Ilkka
Yes, exactly. That's why I'm only posting numbers, because my subjective opinions might be affected by the recent events.
jakeman
You miss the irony of this saying. In normal usuage its used to describe people who manipulate numbers to support a less than credible position. An English prime minister in the 19th century, Disraeli, was more to the point..." there are lies, damn lies and statistics".
Steve42
Illka (and everyone for that matter),
Are you saying that one can seperate 1% THD from 10% in a listening test, or just by looking at a graph?
If it's the former, maybe you should honeslty take the Klippel test. The majority of people that perform this test only have about -12dB to -18dB sensitivity to THD. Off hand I think that translates to somewhere around 13%-26% before most people would even be able to hear THD in the "real world".
If it's the latter than, well it does not matter to me as much. It matters some, but my ears matter more IMHO.
See this article which is quite good: http://stereophile.com/features/306truth/
And yes it's for than just the "tube sound" is preferrable to some people. As I said earlier it could possibly put many of these needless arguments to bed about measurements long before they start.
That said of course measurements matter, but they are not the "end all be all" that some get so worked up about. They should be used as a reference and that's about it, IMO. Ultimately one should let his ears decide which I'm pretty sure is why Craig always stresses listening tests.
Just my .02. Everyones got a different take on things, but we should be here to help eachother not call eachother names and such.
As a side note, I don't think people are as patient in reading eachothers posts. Many will find it easy to jump the gun before we truly understand others points of view. Of course, this does not happen all the time. But I think it could help if we were more patient and truly try to help one another instead of getting caught up in our own opinons and calling eachother names and such.
Cheers,
Steve
Manic Miner
Phew! take one day of, and the thread explodes! :)
Craig: I can see that you think that every test done by Ilkka has been won by SVS. I guess that if you are obsessing on SPL at 20hz, then the answer is yes. But if I were you I would take a closer look at the data for the BK Monolith, not just the 20hz portion, but also GD, and decay, then take a look at the pricetag and report back if you think that SVS were the clear winners of that shootout
Thought I'd interject - I like a couple things about this thread of late:
1 - Discussion is of the issues...
2 - Personal attacks are waning or nonexistent
3 - I am happy about the above 2 things, thanks for making my life easier :)
I
Ilkka
You are right on the spot Manic. I don't want to say this really loud, but you know one can have two Monolith's for the price of one Ultra (back then when we could still buy them). Now, look at Monolith's SPL graphs/10% THD levels and shift the curves/numbers up by 6 dB. Also look at the GD and decay graphs. Is the SVS (Ultra) still a clear winner?
I
Ilkka
I meant I can separate a 1% THD from a 10% in a listening test, when using single or multiple sine waves, especially in lower frequency range.
And yes, I have taken the Klippel test multiple times (actually all of them, not just the 6" Pop) and I score constantly -24 dB or -27 dB. After that it becomes a guessing game.
It is much easier to hear the THD with sine waves than with program material. Especially when the fundamental is a low frequency signal due equal loudness curve. One should also notice that THD represents itself a little bit differently in music signal than with sine waves. The whole waveform (literally thousands of individual tones) gets dirtorted, which we hear as a "distorted sound".
Yes, it is true that higher THD (right kind of THD) can sometimes sound better. Every tube amp owner admits this. And there is nothing wrong with that. Same thing with subwoofers.
I
Ilkka
I get the irony. :)
But I'm standing behind my numbers. Everyone can find an open field, buy a microphone and TrueRTA (it's only $99) or some other program and start testing these subs. I can even explain how to take the measurements I take, just PM me. If you are calibrated similarly for the absolute SPL, I'll guarantee you will get very similar results with me.
Just think about it for a second. Would I be this open regarding my measurements if I had manipulated ANY numbers like you suggest?
jakeman
I lost track of how many threads were closed or deleted trying to reason with you about your biased psedo-scientific methodology. Its not worth revisiting at this great site.
I
Ilkka
I remember most locked/deleted threads related to the measurements Axiom took for Ultra and EP-600/EP-500?
My shootout thread was deleted after you guys attacked on it and blaimed its results were flawed and manipulated. :)
