Ax1lla, , if you want to go with a bit lower powered receiver (and you want super loud) your focus then should be to find speakers that you like that are quite efficient. That means the Sensitivity value needs to be high. (Something like 94 dB / 1m / 2.83V in Half Space would be awesome, but few are at that level in the Budget that I know of). SVS Prime Sensitivity is 85 dB (2.83V @ 1 meter full-space, 300-3kHz). But even these can get uncomfortably loud at 103 dB SPL with all 5 at 75 watts with the listener 8 feet away from them.
(A 94 dB Speaker system will get to 112 dB SPL with the same parameters; which is louder than Jet flyover at 300 meters. You would need almost 10 times the power for a speaker with a Sensitivity of 85 dB to get to that loudness level => if it could handle the power. )
A rule of thumb is a 3 dB increase is perceived as twice as Loud. And it typically takes 10 times the power to to get there with the same speaker (again => if it could handle the power.). The bottom line is the difference between 75 and even 100 watts isn't nearly as significant as a 3 dB increase in Sensitivity. So if you are chasing Loud, power isn't really going to help as much as Sensitivity.
For just starting out, I'd go for the Denon AVR-S950H I recommended earlier and try the SVS Prime Satellite 5.1 system. (It comes with the SB-1000 Pro Subwoofer) If you don't like the speakers you can return them for a full refund, and they pay the shipping (in the USA). They also offer a 1 year upgrade program, with no penalty, if you decide to move up.
I see little downside for you here.
