Yeah, for timoteo and Djeayzonne
What timoteo is saying about the way the bass gets handled in the receiver is correct
IF the receiver is doing things the way it is
supposed to do it.
But like I was saying earlier, some receivers do not handle the bass correctly for some reason. I don't know why, but I know that it happens. And I've had it happen on Onkyo receivers before, so I'm not totally sure what the problem is, but it is NOT sending the bass below 80Hz from the Front L/R speakers when those speakers are set to "small". Again, this isn't the way things are
supposed to work. The receiver is screwing up. But I know that it happens some times, and that's why I gave the advice that I did
If you could do me a favor, Djeayzonne: do you have The Matrix on DVD? Or could you rent a copy?
Set up the receiver as follows:
- All speakers set to an 80Hz cross-over point
- Subwoofer set to "on"
- On the subwoofer itself, turn all the high-pass and low-pass filters off
Put the receiver in standard Dolby Digital listening mode when the movie is playing.
Now go to the "lobby shootout" scene. When the action starts, it will be really easy to tell if your receiver is handling the bass correctly or not.
Do you remember the music in that scene? Most people do - it was very memorable
It's got that really prominent bass riff. On the DVD, that bass riff is mixed into the Front L/R channels - not into the LFE subwoofer channel.
With this setup, if that bass riff doesn't sound loud and clear and prominent - like substantially louder than everything else in the scene - then your receiver is not handling the bass correctly. Based on what you said The Lion King sounds like, I suspect this to be the case.
So, if that bass riff doesn't easily stand out, try this:
- set the Front L/R speakers to "Full"
- Set the subwoofer to "double" or "LFE + Mains" (however it is labelled)
Now try that scene again. You should easily notice immediately that the bass riff really stands out now the way it is supposed to!
If there is some way to select an 80Hz cross-over for your Front L/R speakers and still turn on "double bass" or "LFE + Mains", then that is the preferred setting. But like you said, I believe it is greyed out and you can't select it if you choose an 80Hz cross-over for the Front L/R speakers.
As I was saying before, using the "large/full" front speakers and "double bass/LFE + Mains" setting is not ideal. But in a case where the receiver is not doing the bass management properly, it is the only way to get all of the bass that is supposed to be playing!
In the future, the ideal solution will be to get an external amp for your Front L/R speakers. I've detailed the ideal connection path in that case previously, so I won't repeat it again. But yeah, as timoteo says, the "large/full" front setting with the "double bass/LFE + Mains" setting is not ideal. But it is better than having a whole bunch of bass completely missing!
With the 80Hz cross-over for the Front L/R speakers and the subwoofer simply set to "on", the receiver is
supposed to send all of the bass from the Front L/R channels to the subwoofer output. timoteo's absolutely right about that. But if the receiver is screwing up - as I know that they can sometimes - then it isn't doing things as expected! So that's a bit of an annoyance, but I'm just trying to suggest the best compromise when things aren't working the way they're supposed to
