I just went through my discs, Avatar BD, Fight Club DVD, and Akira DVD. Avatar has no such menu option, and the only thing the two DVDs provide is a test to make sure you have your speakers wired properly.
Anyway, I just bought the Audio Tools app by Six Digital for iPhone, so I want something to test the whole system not just the bass anyway. Any recommendations for something like that?
The Audio Tools app is pretty powerful actually, especially when you add the FFT add-on, which really lets you graph the frequency response well. The only problem is that the iPhone's built-in mic can't measure bass. It's got a filter that cuts off the bass pretty drastically. You can add Studio Six Digital's iAudioInterface 2 to actually get a really good measurement set up if you get a linear mic for it, but it's a bit on the expensive side once you total it all up.
The Audio Tools app is good for a quick and very rough idea of your general response if you use it just with the iPhone itself. But like I say, it's really not accurate for bass readings. The SPL meter is actually very good - but again, just not for bass.
To measure your room properly, here's what I recommend:
Start with a good, linear microphone. The
Dayton EMM-6 is one of the better deals. You can go to Dayton's website and plug in the serial number for your exact EMM-6 mic and get a correction file for that specific microphone that you have! Some folks claim that Dayton's correction files are not perfect. The mic is already pretty darn linear all on its own though, so I don't see it as a big deal either way. You're looking for larger peaks and dips anyway. The EMM-6 won't give you laboratory-grade results - it'll be off by 1-2dB here and there - but that's perfectly fine for your purposes. We're looking for bigger dips and peaks than that
The
Behringer ECM8000 mic is almost identical and pretty much the "go to" mic for most home users. So either of those mics is a great place to start!
The Dayton and Behringer mics both come with a microphone stand clip. You'll want a basic mic stand so that you can hold the mic perfectly in place while you're measuring. You don't need anything fancy, but it's nice to have a boom on the stand so that you can put the stand behind your seat and use the boom to lower the mic into position exactly where your head would be if you were sitting in your seat. Something like this
$15 Pyle Pro Tripod Stand is perfectly fine.
You'll need a basic
XLR microphone cable. Get yourself a nice long length so that it's easy to move around.
Now you need to connect your mic to your computer. Best way to do that is with a USB microphone pre-amp. That pre-amp also needs to supply the Dayton or Behringer microphone with "phantom power", since either mic requires a power supply. The
ART USB Dual Pre gives you everything you need in one, handy, small package
Now you just need software to give you some pretty graphs and supply the test tones.
Room EQ Wizard (REW) is FREE and extremely powerful and flexible. Do yourself a favor and read through the many (and lengthy)
online help files to really get a grip on what REW can do. You certainly don't need to understand or worry about all of it. You really just need to know how to connect and set up your mic, get a basic frequency response graph with 1/24 octave resolution (you can get even higher resolution, but 1/24 octave works well and pretty much catches any problems) and that's about it.
If you find that the PC13-Ultra's 2 bands of EQ are not enough, you can always add an outboard EQ. Personally, I like the
Behringer DSP1124P . It's not too expensive (about $100), it's easy to understand and use, and best of all, REW is able to work with it automatically! All you need is a
USB-to-MIDI cable (about $30-$35), and REW can automatically set up the DSP1124P for you!
There are other outboard EQ units that work with REW as well, but most are more expensive. The DSP1124P, sadly, looks like it's being discontinued, but they're still available for the moment. You might not need an outboard EQ unit at all though, thanks to the 2-band built-in EQ in your PC13-Ultra. 2-bands aren't much, but you should be able to knock down your two worst peaks, which is sometimes enough to get pretty decently flat response, so certainly worth trying first. The PC13-Ultra also has its multiple "modes" of operation with the port plugs and extension settings. Plus there are the room gain compensation settings to counteract room gain in the deepest bass, so the PC13-Ultra actually has significant EQ controls when you combine all of the options, making an outboard EQ unit like the DSP1124P not as likely to be necessary
