Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Finally, small but enjoyable!!!
  1. #1
    Pensacola Hi-Fi is offline Audioholic Intern Pensacola Hi-Fi is a forum member in good standing
    Join Date
    Sep 2009
    Posts
    28
    Thanks Given
    4
    Thanks Received
    2
    Default Finally, small but enjoyable!!!
    I have always wanted to have a 800+ sq foot media room, but in this housing market, it does not look like a move is in the near feature. So, I took a small office/catch all room and made it over.
    LCR are Definitive Di 5.5LCR
    Rears are Definitive Di 5.5BPS
    Infinity Cascade 15 Subwoofer
    HSU MBM-12 mid-bass
    Yamaha Reciever
    Monster Power 5125 Amp
    Velodyn SMS-1
    Sony Blu Ray
    Monster Power Center
    LED - LG 47LW5500
    Palliser Pacifico Power Seats
    I went with the Cascade subwoofer because it would fit behind the seats, but that is not the best placement, in fact may be the worst. The sub does not go that low either. Was going for a clean look since the room was small, but performance is more important and will soon be upgrading to a SVS PB10-nsd and will have to find a place for it.
    When working on the room, we put up some crown molding appx 8 inches down from the ceing and laid rope light (LED) that gives the room a nice setting when viewing with the family.
    It is a small set up, but we are proud of it and thought we would show it off.
    [URL=http://imageshack.us/photo/my-images/822/picture2070.jpg/]
  2. The Following 2 Users Say Thank You to Pensacola Hi-Fi For This Useful Post:
    adk highlander (02-18-2012),its phillip (02-17-2012)
  3. #2
    Alex2507's Avatar
    Alex2507 is online now Audioholic Overlord Alex2507 should be listened to
    Join Date
    Dec 2006
    Location
    Past Hurt ... in recovery
    Posts
    12,131
    Thanks Given
    6,410
    Thanks Received
    6,096
    Default
    It's too clean ... muss that up some and report back.
    For a moment I thought the rug had 'Bose State' written on it.
    I like that crown with the rope lighting too.
    Harry New Year !!! "Never wrestle with a turd. Win or lose, you still end up with sh!t all over you." -Swerd
    "any speaker system in your budget will be an excruciating experience" ~ TLS
  4. The Following 2 Users Say Thank You to Alex2507 For This Useful Post:
    lsiberian (12-15-2011),Pensacola Hi-Fi (12-12-2011)
  5. #3
    j_garcia's Avatar
    j_garcia is offline Seriously, I have no life. j_garcia should be listened to
    Join Date
    Jul 2005
    Location
    San Jose, Ca.
    Posts
    21,295
    Thanks Given
    1,666
    Thanks Received
    3,807
    Default
    SVS no longer makes the PB-10. I'm personally not a fan of in-walls, but the room looks good!
    HT: Emotiva UMC-200, Emotiva XPA-3, 3X GR Research A/V-2s, GR A/V-1s, Epik Empire, Oppo BDP-83SE, URC R-50, APC-H10, Panamax 5100, PS3 Slim120G(500G) Bluejeans Cable
    System Two: Marantz SR-8300, GR Research A/V-2s, Sony SCD-222ES SACD, Panasonic BD-65, PS3 60G (250G), My HT
    Are you sure which side of the glass you are on?
  6. #4
    Join Date
    Sep 2009
    Posts
    28
    Thanks Given
    4
    Thanks Received
    2
    Default
    Thanks! I am looking at picking up a used NSD either here or at Audiogon. I would also go for a HSU VTF MK. I had one of those and miss it.
    As far as the in-walls go.... if I had to do it again, I am not sure I would. The sound quality is better than I thot it would be. I knew I was going to give some up from when compared to a bookshelf and a give a lot compared to a tower, but with the room so small, and going for a clean look, I decided to go with the in-walls.
    My daughters bedroom is on the other side and there is a lot of sound bleeding over... a lot more than I expected. I took the speakers out, lined both sides of the inner drywall with Dynamat and Dynapad (car product) but that only killed it a little... very little. There is no way I can get a decent volume (not loud at all) without waking her up. I might put in a extra layer of drywall and Green Glue on the bedroom side.
    As far as the definitive Di in-walls, I like them! Being able to aim the tweeter was a big plus and noticed a big difference after adjusting.
    I know a on-wall speaker would keep it quieter on the back side, but the clean look was so important, that if I had to do it again, I probably would not change. I'll keep working to fix the problem.
  7. #5
    j_garcia's Avatar
    Join Date
    Jul 2005
    Location
    San Jose, Ca.
    Posts
    21,295
    Thanks Given
    1,666
    Thanks Received
    3,807
    Default
    Aiming of the tweeter is definitely a big plus. I don't mind in-wall/ceiling for surround duty, as I have a friend who did in ceilings and it sounded great. It is just the front stage that I'd probably have issue with, mainly because I have gone through a number of speakers Current speakers have been here the longest though, and don't expect to switch them out soon. I am sure in-wall made the sound bleeding worse, but I don't think much is really going to stop it completely.
  8. #6
    Alex2507's Avatar
    Join Date
    Dec 2006
    Location
    Posts
    12,131
    Thanks Given
    6,410
    Thanks Received
    6,096
    Default
    You sound like you know stuff when you talk about green glue and an additional layer of drywall but just in case you hadn't thought to stuff insulation into the cavity above and below the in-walls I thought I'd mention it. You can also laminate a strip of drywall to the inside through the speaker hole with mud to add mass. It can't hurt, right? and it won't impact the finish on the bedroom side.
  9. #7
    westcott is offline Audioholic General westcott is considered a mentor
    Join Date
    Jul 2005
    Location
    South of Houston, Texas
    Posts
    1,452
    Thanks Given
    187
    Thanks Received
    176
    Default
    Small spaces are always a challenge but you have done an admirable job and it looks nice and clean and I am a big fan of the uncluttered look.
    Thanks for sharing.
    His and Her Room!
    Klipsch RF7's,RC7,RS7's,RSW15,Denon 3805, Samsung BD-P1200, Toshiba HD-XA2, VIP622 HD DVR, 100" BW Carada Critereon, Panasonic AE700u, Wega 27",300 Disk CD Changer,Laurier-Carino AV Credenza, Logitech Harmony 1000 with RF extender, Impact Acoustics 5x1 HDMI switch,Tripp Lite HT10DBS, Blue Jean Cables
    March 2007 Issue Home Theater Magazine and Audio Video Interiors
  10. The Following User Says Thank You to westcott For This Useful Post:
  11. #8
    Join Date
    Sep 2009
    Posts
    28
    Thanks Given
    4
    Thanks Received
    2
    Default
    I had heard that stuffing the inside of the wall cavity with fiberglass would cut down on some of the sound, but then I had someone who 'knew what they were talking about' tell me that it makes it worse. Did not make sense to me how it could be worse, but I might give it a try.
    Thanks for the info.
    Living Room Main System: Marantz 6500, Emotiva XPA-2, XPA-3, Mirage OMD-28, OMDR, OMD-C2, SVS PB12 Ultra/2, Velodyn SMS-1, Monster Voltage Stabelizer, Sony BD, Mits 65 Diamond
    Man Cave: Yamaha Reciever, Velodyne SMS-1, Sony BD, Monster Amp MPA 5150, Definitive Di 5.5LCR, Di 5.5BPS, SVS PB10-NSD, HSU MBM-12, PS3, Sony BD, LG 47LW5500
  12. #9
    Adam's Avatar
    Adam is online now Audioholic Jedi Adam should be listened to
    Join Date
    Jul 2006
    Location
    Tucson, Arizona
    Posts
    26,523
    Thanks Given
    7,584
    Thanks Received
    9,127
    Default
    I dream of someday hearing a woman say your thread title.
    That set up looks great - nice, clean, and tidy. Don't listen to Alex.
    Mains and Surrounds: NHT 1.5s, Center: NHT AudioCenter-1, Subs: SVS PC13-Ultra, SB13-Ultra, Receiver: Pioneer Elite VSX-23, Amps: Emotiva RPA-1, POS-1, Display: Panasonic TC-P50G10
  13. #10
    avdoubleu is offline Audioholic Intern avdoubleu is gaining some recognition
    Join Date
    Nov 2011
    Location
    Folsom, California
    Posts
    39
    Thanks Given
    20
    Thanks Received
    15
    Default
    All those remotes!!!!!!!!!!! If my daughter got in there they would all be missing in the abbys.
    65" Panasonic Viera - TC-P65S1
    Samsung Blu ray - BD-C5500
    ASUS Laptop - U50V
    Iomega Presige 2TB External Hard Drive
    Yamaha Receiver - RX-V565
    Subwoofer - Rythmik FV12
    FL+FR - Infinity P362
    BL+BR - Infinity P162
    C - Infinity PC350
    Nintendo Wii
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
