Yamaha AVENTAGE RX-1080BL vs RX-V685BL, and Elac F5.2 vs F6.2
  • Thread starter Thread starter john20182050
john20182050
108
0
18
46
Considering either one of these to buy. Which is a better choice? What do you guys think? The differences are high lighted.
https://www.amazon.com/Elac-AVENTAG...+debut+2.0+5.1&refinements=p_36:100000-170000
  • (1) Yamaha AVENTAGE RX-1080BL 7.2-Ch Network AV Receiver
  • (1) Pair of Elac F5.2 Debut 2.0 Floorstanding Speakers
  • (1) Pair of Elac Debut 2.0 B6.2 Bookshelf Speakers
  • (1) Elac Debut C6.2 Center Channel Speaker
  • (1) Elac Debut Sub3010 Powered Subwoofer
https://www.amazon.com/Elac-Theater...+debut+2.0+5.1&refinements=p_36:100000-170000
  • 1) Yamaha RX-V685BL 7.2-Ch 4K Network AV Receiver
  • (1) Pair of Elac F6.2 Debut 2.0 Floorstanding Speakers
  • (1) Elac Debut 2.0 C6.2 Center Channel Speaker
The 1080 has preouts in case you need an external amp. The 1070 might be cheaper than the 1080.
  • Like
Reactions: TechHDS
For the same money, I also prefer the 1080/F5.2 combination. From what I can see, the larger F6.2 would offer no advantage unless used without subwoofer. I suspect those speakers should always be used with a subwoofer and crossover set high.
  • Like
Reactions: TechHDS
Yeah, I would get the Yamaha RX1080 package.
  • Like
Reactions: TechHDS
What does "BL" in the name mean if anything at all?
Thanks all. Yes, even I thought 1070 is a better option.
The only way 1080 is better than 1070 is if Yamaha has hidden hdmi 2.1 abilities in there that can be enabled in a future firmware update. I don’t think that is the case though.
