Would a Power Amp Help my Denon Receiver?
Michael Hogan
I recently purchased a Denon AVR-X1300W Integrated Network AV Receiver.
I'm running:
1. Front R/L- Mirage FRx-Seven Floor Standing (power handling 250W)
2. Surround L/R - Celestion F30 Floor Standing (power handling 120W) or Mirage FRx- 3B Bookshelf (100w)
3. Surround Back L/R- Polk F/X i A6
4. Front- Celestion (my Klipsch RC-250 will be in in 3 weeks)
5. Subs- Mirage 10 inch FRx- S10 and Cerwin Vega 10 inch
Problem:
The front speakers sound crappy in stereo mode (2 speaker). When I biamp the front speakers using the surround back I get crisper, cleaner sound, but I lose the surround back speakers. The sound is better.
My question:
Should I purchase a power amp? I notice my receiver has a pre out. I have never done this, and I don't have a clue where to start or what to look for.
Mike
everettT
everettT
I'm running:
4. Subs- Mirage 10 inch FRx- S10 and Cerwin Vega 10 inch
Problem:
My question:
Mike
Hard to believe biamping off the same power supply would make any difference at all. I think your denon only has zone 2 pre outs so that's gonna kill the external amp.
Well, it is hard to say from here. Room has a major impact. Proper location of speakers in a room is also important.
Without researching speaker sensitivity and the receiver's power capability, hard to say.
Was the sytstem level matching set up properly?
As stated, bi-amping passive speakers is not productive.
Perception can be confusing and misleading, don't forget.
Verdinut
Verdinut
It looks like your AVR is not powerful enough to drive your speakers. It's power supply is limited and cannot provide enough current for the Mirage transducers.
The solution would be to replace the Denon with a receiver that has pre-outs to enable you to use external amplification. My suggestion would be something like the Marantz SR5012 or the discontinued SR5011 if you can find one with an interesting discount.
For external amplifying, there are several options such as one of the Outlaw and Monoprice Monolith brand units at affordable prices.
I recently purchased a Denon AVR-X1300W ..
Did you say Denon X1300?
The X1000 and X2000 series don't have pre-outs for an external Ampl
You need a Denon X3000, X4000, X6000, or X7000 series to use an external Amp.
Verdinut
Verdinut
The OP was not passively bi-amping with his X1300 AVR. He was using the surround back amps to actively bi-amplify the left and right front channels, a feature found in some Denon and Marantz receivers.
As for the Mirage speakers, I suspect that they represent a low impedance at low frequencies which demand too much current from the AVR limited power supply.
Verdinut
Verdinut
On their site, Denon specify that the AVR-X1300W has a 0.2 Pre-out. Does someone know what it means?
They are indeed very clear in their information!
Michael Hogan
So to be clear, the Pre Out (Zone 2) L/R on the AVR-X1300W cannot be used for external amplification?
Did he use an external Crossover or somehow remove the internal crossover of the speakers?
Or did he use the LFE of the AVR and use an external amp to power the bass section of the speakers?
Otherwise, it looks like passive bi-amp to me.
By definition, Active Bi-amp means you have to use an external Crossover before amping the speakers.
So if he is simply using the AVR's back surround amps to "bi-amp" his speakers, it's just passive bi-amp or just bi-wiring.
Notice how when the Denon X1000 series is using only 2Ch, the power output is 126WPC x 2Ch. But when it is using 5Ch, the power output is only 78WPC x 5Ch?
So the AVR is not sending 126W x 2Ch and another 126W x 2Ch from the surround amps.
It is sending 78WPC x 2Ch + 78WPC x 2Ch from the surround amps, which is really not any more than 126W x 2ch.
It's really a gimmick.
Here is another example - the $850 Yamaha 775 AVR.
For 2Ch, it's almost 150WPC. But for 5Ch, it's only about 50WPC.
So it would be either 150WPC x 2Ch or 50WPC x 2Ch + 50WPC x 2Ch.
https://www.soundandvision.com/content/yamaha-rx-v775wa-av-receiver
With the Denon, it's about the same power output, which is already a total waste of time. With this $850 Yamaha, it's actually worse!!!
Michael Hogan
Hi Steve
I have two pre outs for 2 subs and a pre out l/r for Zone 2
That means it has an internal splitter for a two sub pre-outs, not very meaningful at all. You could have a ".1" sub pre-out and use a splitter to same effect unless the avr has the ability to separately set level/delay for two subs (like with SubEq/XT32)
ps welcome to stupid poop marketing
Michael Hogan
Makes sense now. So my "Zone 2" with the use of a good stereo amp could power good speakers and give me good stereo sound? OR will I also be limited with the kind of Stereo Amp I can pair with the Denon?
Michael Hogan
So a stereo amp can be "hooked Up" to the Denon Receiver through the Zone two L/R. So I don't make a second mistake and waste more money, what stereo amp should I consider?
Verdinut
Verdinut
No. With my Marantz SR5010, I did actively bi-amplify the two front left and right channels for a while before purchasing the QSC DCA1222 Power amps for the purpose. This AVR provides for active bi-amping with internal electronic crossovers:
That is what the OP did with the X1300.
Verdinut
Verdinut
The Denon X1300 does not have pre-outs for the front left and right channels, so it's impossible to connect an external amp, except for Zone 2.
You would need to get an AVR with the appropriate pre-outs. See post #4 for my recommendation.
Cheers,
everettT
everettT
That is called passive biamping, you still use the speakers passive crossover. Only a hand full of speakers are designed for passive biamping ( and they are designed with jumpers that reconfigure the crossover) that are available.
Michael Hogan
Multi-Source/Multi-room
With the AVR-X1300W it's possible to enjoy 5.1-channel surround in one room, while another 'zone' plays another source–such as CD or streaming audio. You can simply connect a pair of stereo speakers to the multi-room amplified outputs. Or, connect a separate stereo amp and speakers to the Zone 2 pre-outs, allowing full 7 channel surround sound in the main room with stereo in the second.
