Brian_the_King
Ok, I can't really stay on any longer [family coming over], but I'm really liking your idea. I'll go mull things over, and be back later with more questions I'm sure
Thanks again.
Thanks again.
Would you like to explain a little more your first paragraph or so? I really am quite surprised by those statements. While I may seem to be biased towards Axiom as an owner, Even if I werent I havent seen credible evidence to suggest what you have stated about them.I would not recommend buying the Axioms as an upgrade. Axiom speakers are not evidenced to me to be of any special value. They measure poorly compared to other available speakers in the same price range. I am not even sure if they would be as good as the Primus 250 speakers(the primus probably has a higher quality midrange driver, a smoother response curve and better designed crossover and probably has superior off axis response). If you are looking to economize and still yield large improvement, I can specify physical modifications to that speaker that you can perform to substantially improve it's clarity/resolution, and in addition, add stereo subwoofers(one somewhat near each main speaker) with an active crossover used to split to the speakers/subs at about 80-90Hz. If you really want new speakers that are a substantial upgrade, save up a bit more, and go for something like a B&W CM7. But I would not be surprised if this was not as good as the modified Primus 250s with stereo subwoofers.
-Chris
You only need refer to the Soundstage NRC lab measurements of various Axiom speakers to witness the relatively rough response curves. Combine these average driver/crossover combinations with the standard resonant cabinets and you have nothing of any special value. The single aspect of Axiom speakers that appears to be better compared to some others, is the somewhat smoother off axis curves. Many of the original Primus systems, however, have exceptionally smooth response curves, and considering the simple crossovers used in Primus units, this indicated superbly well controlled drivers. My conclusion is further supported by my own measurements of various Primus drivers. In fact, I will be using Primus 360 4" midranges in a new project I am doing, that will cost several thousand dollars to complete. That is how confident I am in the quality of this particular midrange unit after analysis.Would you like to explain a little more your first paragraph or so? I really am quite surprised by those statements. While I may seem to be biased towards Axiom as an owner, Even if I werent I havent seen credible evidence to suggest what you have stated about them.
Yes, that looks correct.
Certain speakers have unusually good drivers and crossovers that are rare in a given price range. Most of the Infinity Primus original line (xx0 series) comes under this flag.So basically what your saying is that any speaker with "average driver/crossover combinations" with the "standard resonant cabinets" is a peice of crap compared to a severely modified Infinity speaker.
I do not understand. Please re-phrase.I really do not see how a cabinet designed to solve problems that occur with speaker cabinets in a unique manner is somehow standard compared to just about every other speaker manufacturer out there which simply builds what i actually would consider a standard cabinet and then chooses to either put a bandaid on them in the form of internal bracing which most of the time is barely adequete in the price range we are talking about.
Most of the original Primus line has ridiculously good drivers and response plots. I have not measured the model 250, but based on many others, I assume it is designed with the same common characteristics. The Axioms I have had the opportunity to observe measurements of, on the other hand, were nothing more than average. Relatively rough response with relatively high linear distortion. In the case of many of the original Primus units, the cabinet is primary problem holding them back from better sound quality. Of course you can not expect to get equal enhancement from any speaker by improving a specific isolated problem -- but in this case of the Primus 250 -- the cabinet is likely the single biggest problem.How can you say that the speakers he currently has probably has a better midrange driver and probably better off axis response. Without a direct comparison. As anyone who has designed speakers or heard many speakers in their experience which I would imagine you do and you have, would know is the quality of the parts of something doesn't make a piece automatically good. Its the sum of those parts and the way its put together. You could get the most expensive drivers in the world and put them in a cabinet with some kind of superconductor internal wiring and a finish made from bald eagle skins. Doesn't mean its going to sound any good.
I referred to a source (Soundstage) of accurate measurements of several Axiom speakers. Stereophile has several Primus speakers in their measurement database. Look for the Primus 150 and Primus 360. The Axioms have rough/ragged responses indicating poor driver behaviour as compared to the lower cost Infinity units, which apparently have substantially better drivers.The main problem I have with your original statement is that you are talking about something that is based on virtually nothing that correlates to how the speakers actually perform.
-Chris
The trend I am referring to is not that of the fine ragged features -- Stereophile also uses some average smoothing. The window average also performs some smoothing(you can refer to the 1st top trace in the waterfall plot if you want to see the 0 degree single measurement on Stereophile). The issues I am pointing out are the large/gross overall variations in response, which are not the result of smoothing. Soundstage has the same window measurement. Refer to the -/+ 15 degree average about 3 or 4 graphs down on Soundstage measurements. This is the same 30 degree window Stereophile uses. This window does not remove the gross errors as found on most of the Axiom measured examples.I looked at what I think are a couple of the response graphs that you refer to. At Soundstage I looked at the measurement of the Axiom M80v2 and at Stereophile I looked at the Primus 150 and 360. You are right that the Axiom graph looks ragged compared to the Primus. I also looked at graphs of other speakers on both sites and noticed a trend. All the graphs at Soundstage looked ragged and all the graphs at Stereophile looked smother by comparison.
I’m guessing it has to do with Stereophile plotting a frequency response averaged across 30 degrees horizontal while the Soundstage graph is showing three distinct plots, on axis and 15 and 30 degrees off axis. I imagine if those were averaged the Axiom graph would also look smother.
I specified how to do this in the long post.I appreciate the continuing discussion, grunt and haoleb; the more I know/see from both sides, the more it helps me decide what I want to do before possibly destroying my speakers
wmax; I still have not decided, if I do go forward with this, which method to perform. Either way though, I don't know how I would go about taking the cabinet apart. How does one accomplish this?
If one does not enjoy the sound of a completely neutral speaker it is still the best starting point as adding a quality and still relatively inexpensive digital equalizer to the line will allow for nearly any system response desired with proper use.I know your choices are limited but you really should try to listen to as many different speakers as you can. You may decide you prefer speakers with a particular sound that is not necessarily neutral.
I think you are missing the point of having stereo subwoofers in this application. If the level two modification is made (which is the only one I would personally consider, but I am in the process of designing some speakers considered over the top by nearly every [uninformed] DIYer) then there will be substantially less volume within the cabinet for the driver this will cause the usable frequency range of the tower to likely be between 80-100Hz thus the stereo subwoofers will need to be placed within three feet or so of the towers due to localizability of the frequencies that will be required of the subwoofers for proper frequency response.Have you compared the stereo subwoofer design with dual subwoofers placed to help balance room resonances. I realize results are very room dependent but the idea of separate subwoofers for each speaker has interested me for some time.
http://www.totemacoustic.com/us/products/columns/sttaf/specifications/Hey all.
My system is below, but if you'd rather not wade through pics and everything here is the condensed version;
Infinity Primus 250 [$400 new, when still in production]
Denon DRA 395 [80Wx2 w/ 0.08% THD @ 8Ω 20Hz-20KHz] [$350 new, when still in production]
Denon DCM 280 [$200 new, when still in production]
I hope to replace my Infinitys with a pair of Axiom Audio M60 V2s soon [especially with this free gloss upgrade going on], and I just wanted to ask if anyone thinks the speakers will be 'too good'/'revealing' for the rest of my system.
I'm not sure how far the Denon gear will take me, and I know its not the same in every situation, but I want a better idea. What do you think proper amount to spend on speakers is, given the other stuff in my system? Are the M60's just right? Could I spend more and not be 'bottlenecked'? Should I spend less?
Lend me your thoughts.
