The Numenorian said:
Let's say that I am currently using a Yamaha RX-V2500.
Let's also say that I am using some Axioms in 5.1:
M60 for mains
M3ti for surrounds
VP100 center
EP350 sub
Now then, will adding an external amp at about 150 wpc/constant improve sound quality, or just volume? I am using a pretty large space, about 2200ft^3, and the 2500 can only do about 60-70 wpc/all 5 driven.
Now, if I added an amp just for the main speakers, would that make my sound lopsided? Or could I utilize the receiver's equalizing (auto and manual) to take care of any such side effects? Thanks.
*btw, awesome forum...my new favorite*
This depends on a few issues. Firstly, do you perceive anything that doesn't sound right as your system is now?
How loud do you listen, spl wise? How sensitive are those speakers? How far away from the speakers? Music in 5ch mono? Perhaps none of your software has full signal output at the same instant?
these affect amp performance.
Excluding the peak demands for a second, your yams 1 watt will sound the same from the recommended amps by others, or the 10 watts, or the 50 watts. If your needs are such that you exceed the design limits, that is a different issue.
Adding external amps would not be a problem. You will level match the outputs. If you want to EQ, the Yam will do it to its capability.
I see those speakers are 93dB spl sensitive in room, pretty good, and 8 ohms, an easy load. Not sure what you will gain from external amps with these speakers, as they will get plenty loud.
