I have never, ever, ever, ever seen a company owner stoop to such aggressive levels of marketing of their own product on the bbs as Tom Vodhanel of SVS has done here. Same old line by line laundry list of features, again and again and again and again. Pretty sick stuff. There goes my respect for the guy.
Ok, now for some more. Quite clearly SVS has copied several design ideas from Hsu Research. For someone to claim otherwise is lying through their teeth.
Slowly but sure, SVS has copied almost all of the major design points from Hsu Research subwoofers:
*Tall ported cylindrical enclosures
*Large ported box enclosures
*12 inch drivers
*10 inch drivers
*Long flared 4" ports
*Long flared 3" ports
*Variable tuning via port plug
*Custom eq for variable tuning modes
*Subsonic filtering
*6th order amplifier design
That's not to say that they shouldn't, since Hsu Research makes the best value products on the market (IMO). But the true visionary here is Dr. Hsu, and always has been Dr. Hsu.
And if you are going to copy design elements, at least have the decency to admit that you did so, and give credit to the one who came up with many of these ideas in the first place.
Obviously, to prevent from being sued (although I think they could have been sued for trade dress if Dr. Hsu wanted to), they had to change things up a bit (mix up the driver firing direction; mix up the port config; mix up the aesthetics). But there is no denying that their entire subwoofer philosophy stems from root technology that Hsu Research introduced with the TN1220HO, and then VTF-2, and then VTF-3.
To be fair, they have come up with some of their own ideas over the years. But then again, who wouldn't? Powered cylinder comes to mind, although no self-respecting engineer would ever want to cut the cylinder simply in order to mount an amp there. Personally, I wouldn't touch their powered cylinders with a ten foot pole because of that, but then again it is convenient for some. Of course, they have also come out with dual driver products. Their dual driver subwoofers are compromised in some ways vs their single driver subwoofers. Their dual driver subwoofers have a higher tune with all ports open, and barely have more internal volume than some of the single driver models like the 12-Plus. This approach is not really novel, but it does cater to certain interests.
Moving from 350 watts to 500 watts of RMS power is not really a big deal. It's more marketing than anything else. This would lead to a virtually undetectable increase in output, no more than 1db. Also, each amplifier and design has various efficiency tradeoffs, so it is misleading to compare only based on RMS, or only peak, power.
Hsu's new technology seems to give them an edge on their ported competition. Dr. Hsu is yet again redefining the ported subwoofer market.
