Where to buy 10 Ga speaker Cable and advice on setting up RBH SX-T1/R
  • Thread starter Thread starter KEW
KEW
KEW
11,572
0
113
Jowjah
I will be receiving these speakers around the end of the week and want to do what I can to be ready for them!
Basically, this is the upper half of the SX-T2 (link to AH review below) with the upgrade to the reference drivers.
Audioholics review of RBH SX-T2
In this review, in the section addressing impedance and phase plots Gene says:
In my experience, I haven't measured a more benign loudspeaker load. Based on these measurements, and the high sensitivity of the design, any decent amplifier (even a rigid receiver) should be able to drive these speakers quite well.
Based on the low impedance profile of the T-1 at high frequencies, I recommend using low resistance cables (10AWG or less) to minimize potential frequency variations.
The above SX-T2 is the proper physical configuration, but the T-30LSE reviewed below gives uses the exact drivers of the SX-T1/R ("/R" = Reference drivers). The drivers are laid out in the same arrangement, however this speakers combines the upper and lower module into a single cabinet.
Audioholics review of RBH T-30LSE
The saddle point in the impedance graph lies just below 20Hz. While these speakers represent a relatively benign phase shift of +12 to -30 degrees across the entire audio band, the dip of 3 ohms centered around 90Hz and 2.5 ohms above 6kHz gives concern for driving them with amplifier of modest current output. I suggest using a beefy amp safely rated down to 4 ohms and definitely using an amplifier with a lowish output impedance to minimize frequency response variations.
I'd appreciate any comments, but here are my specific questions:
1) Source for 10 GA speaker wire. I am not interested in paying more for pretty, however, I do place a value on cables that are not stiff. So a simple, but pliable 10 GA speaker cable is what I am after.
2) I'm not sure what "an amplifier with a lowish output impedance" is! Does that mean an amplifier capable of lowish output impedance or something else?
3) Ideally, I would like to use a Niles SI-2150 (specifications listed under "Product Highlights" in Crutchfield link below). Any concerns here?
Niles SI-2150 specs via Crutchfield
4) IIRC, these weigh in just under 100 pounds. Any recommendations on speaker stands?
Thanks for your help!
Bluejeans offers Belden 5T00UP for $1.16/ft. It is still not so easy to flex, but a little more pliable than most 10AWG. It looks weird though because it is just lightly sleeved, as in you can actually see the twist.
This is the stuff I use, with the white jacket.
  • Like
Reactions: KEW
I’ve owned the SX-T1/R (part of the SX-T2/R towers) for a few years now. The only cables I’ve used are 12G, not 10G.
As for amps, I’m using the ATI AT2005, but I’ve also used just the Denon X-3100 and AVR-3312 (without ext amps).
They are very sensitive and get very loud with just the AVR, so the Niles ext amp should do great.
As for stands, I would put the 70-pound SX-T1/R atop (dual) Subwoofers (similar to how my T1s sit atop my 1010 subs). :D
  • Like
Reactions: KEW
No wonder you couldn't hear the difference bi-wiring makes. :rolleyes:
Edit: 14/4 gets you 2 11ga legs and is flexible ... and it totally smokes 12 ga in tonality. Duh. Sheesh. :D
Oh shoot. This is embarrassing. My speakers cables are Kimber Kable 8PR.
For some reasons I thought the Kimber 8PR was 12G, but it’s actually 10G. :oops:
  • Like
Reactions: KEW
You can get Monoprice 12AWG -4 Conductor cable and twist each color together and you obtain the equivalent of a 9 Ga wire.
Kurt doesn't need 9 ga at the expense of expense and stiffness. The 14/4 deal about maxes out some of my banana plugs as well. Only crazy people need 10 ga and down. My wire goes to ... eleven. :D
IMO, stiffness is not an important factor for speaker cables as they are not to be routed or moved around in normal use. I am using 12/4 cable between amplifiers and my three subs. I don't see the problem some are complaining about.
  • Like
Reactions: KEW
Kurt I think you should get multiple cables and since you have a coupla AHers not too far, conduct a little audibility test for us ! :)
Oh and congrats on the new toys! You selling anything good to make room for them or just find other uses like I do?
  • Like
Reactions: KEW
So, those bad boys still boxed up or have you gotten a chance to open them up? :D
I'm sure we're all anxious to see your review of them. ;)
And pictures! :D
  • Like
Reactions: KEW
And pictures! :D
I'm hoping to get to this soon, but know it won't be too soon!
I've unboxed one and hooked it up... it sounds great, but certainly I expected that. The real test is how it compares to some other great sounding speakers.
I own the reference version of the towers. I’m using 10g wire for the entire system. I’m driving the subA with the excellent RNH SA-400 amps. Wow do they push the current. The upper portions are driven with the Pioneer flagship receiver VSX-59TXI that’s pushing well over 200 wpc in 4ohm. I am using the hardware from RBH that joins both sections. I purchased very heavy 1/4” steel out rigger brackets from RBH. The towers are near impossible to move. I have also used a very powerful Crown amp to drives the subs with great results.
  • Like
Reactions: KEW
