And how do the crossovers get wired together?! Hope I can find a good thread on someone that's built these!? My knowledge of crossovers is minimal at best
! Maybe time to become a member of the partsexpress forum?
As part of their effort to sell this kit to newbies, Parts Express has
videos for cabinet and crossover board assembly!. As you get to that part of the job, if you have questions, ask us here
. I haven't seen the instructions that come with the kit, but I expect Parts Express did a good job with that.
One other question, does anyone have pics of their cabinets w/ grills? I see all kinds of speaker kits and none of them have grills. Just curious to see how the grill frames are made and looking for some different ideas for how they fit the speakers.
For grills, use thin plywood or pressboard, ¼" or less. Parts Express sells
grill cloth,
plastic grill attachment doohickies, or
small magnets. Make one large cutout opening for the all drivers, paint it black, and use spray adhesive to attach the grill cloth. If you want to get audiophile extra credit, use a round over bit to take the edge off the inside of the cutout opening.
I like using the small magnets to attach the grill to the cabinet. Before cabinet assembly, bore 4 holes large enough for each magnet in the corners of the grill board, and epoxy them in place. Bore 4 more holes for the magnets in corresponding positions on the back side of the front panel (often called the front baffle) and epoxy the magnets into the holes. Make the holes deep enough so there is roughly ¼" of wood remaining between the buried magnet and the corresponding on in the grill. When you're done, you'll have grills with invisible attachment hardware. If you're going to veneer the cabinets, you can bore the magnet holes into the front of the baffle, spackle & sand as a final fill to cover the holes, and veneer over them.
Those plastic bits also work, but they are visible and can break off.
