Sheep said:
Here you say they DON'T listen to subwoofers.
And here is your contradiction.
Again, to easy. Then the fact that you said FR graphs are the only measurements.
Easy.
I think we all know who needs to step back for awhile.
SheepStar
Sheep, Now think through this very carefully: Eric does not conduct the AVTalk tests. Charley conducts the tests. You thought your "point was proven" because, in your words, Eric "a man who takes MANY measurements, cares about sound", when it was Charley taking the measurements.
If you need help understanding the logic here, please ask. We will guide you through this difficult task.
The tests themselves are fine for putting together a series of graphs. It is the conclusions which are the problem. For example, on many occasions, people have used just the numbers from AVTalk to declare a "winner" between two subwoofers.
Now, if someone wants to say one subwoofer is louder than another after looking at these graphs, that is possible. However, louder and better are not necessarily the same thing.
And Sheep, I did not say that FR was the only measurement. Try sticking with facts, ok ?
