Why do you think this is a necessary priory? The don't have to measure exactly the same. I am sure same models do not measure exactly the same, if you have enough decimal places in the measuring tool
Most of the measurements are below the threshold of detection already. So it matters not if one is .04 and another is .01. If the component is not driven beyond its design limits, that is the key to comparing components.
However, as we do see in unbiased reviews from time to time, the specs listed by some companies are not true.
Maybe a different THD is used for power ratings? So, it is somewhat a biased rating when the two conditions are not the same.
So here we go: Amp #1 sounds brighter/thinner than Amp #2 because the specs for Amp #1 are not 'true' and it is incapable of powering speakers they should be able to power...resulting in a bright/thin sound.
Bright, thin is a frequency response issue. They are flat enough to be below the thresholds of detection. Bogus issue.
Several years ago, Consumer Reports slammed a popular gas company for formulating their gas to give a higher octane reading when tested than what was truly present.
Or, was it that the company just used a non standard method to calculate it. Since I subscribe to CR, I don't recall this issue. Please cite it.
Now what would be really useful is if mtrycrafts got out some of his toys and started reporting to us data concerning companies that fudge their specs. I'm not being sarcastic...
Ah, reinventing the wheel??? Aren't there enough mags printing numbers?
