Ok, But, What About A Cable Solution For My Sub?
OK,
The 4ohm speakers are going to be alright. Thank you all for the fast input.
The cable issue is still hanging, and the one-line answers about "get an amp" are fine, but impractical for me. I live in an apartment with neighbors below me, my sound room is tiny, and I'm not overly affluent, so "more power" is not an on-topic answer, really.
The question is whether there is a cable (adapter/ready-made) solution to get my sub hooked up from the standard RCA Subwoofer Out on the NAD to my speaker post/banana clip terminals on my Sub.
I'm hoping that this second question is a yes or no answer, with the yes answer ending with: "... this is what it is called, and this is where you can get what you need, and a link." I can't believe that there is no cable solution, considering the wide array of equipment out there. But, then, I'm trying to do an awful lot with a tiny bit of money.
I don't plan on buying another component this year, and if I cannot hook up this sub, I will sell it, and plan for something usable down the road.
For the music I listen to, and the few movies that I watch, 4 speakers may be plenty.
Thanks for your comments so far... One big worry has been relived.
Tony B.
